Tailight not working
Old Aug 25, 2010 | 06:13 PM
stng_96's Avatar
stng_96
Default Tailight not working
Hey guys, plane and simple, my taillight is not working at all. There are three wires going to the bulb. Blue, red, and black. When the key is on, I have power on the blue wire just setting, and no power when I pull the front brake. I dont have power period on the red one.... And of course, the black should be ground. Any ideas as to whats going on?
Old Aug 25, 2010 | 06:42 PM
ratt196635's Avatar
ratt196635
check the rear brake pedel to see if it will work the brake light if not i would say its the switch in the switch houseing if the rear dont work the light too check to see if you have a blown fuse or have riped out the wires under fender
Old Aug 25, 2010 | 06:45 PM
stng_96's Avatar
stng_96
I guess if the ground is messed up under the fender it could cause it. Would the switch in the bars cause both running and brake light to be off?
Old Aug 25, 2010 | 06:55 PM
ratt196635's Avatar
ratt196635
not really i would check fuses and wires under the fender i had mine ripped out once and had to fix them
Old Aug 26, 2010 | 02:23 PM
cbmk1's Avatar
cbmk1
i had the similer prob with my old sporty and the wires under the finder came out of the holders and rubbed the tire and was grounding it out easy fix hopefully thats the prob
Old Aug 26, 2010 | 04:04 PM
nkauf21's Avatar
nkauf21
Check the wires to the turn signals running under the fender. I rubbed through mine on one side and lost my brake lights and that turn signal.
AustinBadley
Electrical/Lighting/Alarm
Sep 28, 2016 10:38 AM
trace2008
Jun 14, 2015 06:52 AM
little stew
Apr 7, 2013 04:07 PM
usmc_jbw
Aug 13, 2010 08:29 AM
Outlaw44
Oct 8, 2009 08:49 AM
