Military Base decals on a 2011 FXDF
Old Aug 31, 2010 | 02:01 AM
jpetrocelli's Avatar
jpetrocelli
Stage II
Default Military Base decals on a 2011 FXDF
Hi everyone. I bougt my first Harley this past Friday, a 2011 Fat Bob in Denim Black. I love it. Completely different riding experience But, alas the weekend is over and I need to get to work. I work on a military base and need a good place to put the decals. I really don't want to put it on the fork. I have a piece of metal that I could affix the decals too, but I cant seem to find anywhere other than the brake calliper to bolt it on.
The metal plate is about 1/16" thick. Can I safely thread the stock calliper bolts through the plate, and back through the frame and into the callipers, or should I just suck it up and affix them to the fork?
Joe
Old Aug 31, 2010 | 02:03 AM
Luxer's Avatar
Luxer
You could always fabricate a plate and run it through the bolt on your forward controls. That is what I have seen a lot people do including myself.
Old Aug 31, 2010 | 03:54 AM
Cowpokey's Avatar
Cowpokey
I put mine on the frame neck, red arrow. I've seen others use a plate and attach it to the fender mount, yellow arrow.
Last edited by Cowpokey; Aug 31, 2010 at 03:58 AM. Reason: Just realized the OP wouldn't be able to see the pic...
Old Aug 31, 2010 | 06:01 AM
blueangel73's Avatar
blueangel73
Talk to your dealer, if it has a good amount of customers that are military then they should know how to get the decal plate the mounts to the front caliper. You can remove the to mount bolts and there are two holes on the plate that are designed to aline with the mount holes, just put the bolts back through and re torque. Or you could do what I did, I removed the two sets of bolts, nuts and washers on the left side fend mount, put the bracket between the fender and the fork leg using the top hole, located where I needed to drill the second hole, removed drilled, debured, touched up inside of new hole (to prevent rust) and reinstalled. Tucks it in a little behind the fork so it doesn't look bulky.the pics below are both ways of mounting as I discribed. The one with the red sticker is mounted per design, the one with white sticker is the way I modified it.
Attached Thumbnails Military Base decals on a 2011 FXDF-sb26.jpg   Military Base decals on a 2011 FXDF-sb27.jpg
Old Aug 31, 2010 | 06:44 AM
HBomb74's Avatar
HBomb74
When I was in the military I bought a flexible refrigerator magnet large enough to fit the decals then trimmed it for the perfect fit. then just slapped it on my tank or fork or whatever. most of the civilian gate guards never paid very much attention.
Old Aug 31, 2010 | 07:14 AM
DarkHorse88's Avatar
DarkHorse88
I'll also be doing this soon. Did you all buy the plates or fabricate yourselves? And if you purchased them, where?
Old Aug 31, 2010 | 07:21 AM
blueangel73
When my dealer opens I will can them and greet the part number and any other info I need and will post it.
Old Aug 31, 2010 | 07:37 AM
rokrawlr's Avatar
rokrawlr
Mine is on the frame down tube right by the clutch cable. It's out of sight but not hard to find.
Old Aug 31, 2010 | 08:22 AM
overhead's Avatar
overhead
I made one using a thin piece of metal and attached it to the caliper bolt. It has been there for a couple of years and has not caused a problem.
Old Aug 31, 2010 | 09:00 AM
Wonkaboy's Avatar
Wonkaboy
Put it on your helmet ....
