Primary Cover Gasket Question
Old Aug 31, 2010 | 01:00 PM
dFREDb's Avatar
dFREDb
Default Primary Cover Gasket Question
Just replaced the outer primary cover gasket and tower gasket. After a 30 mile ride, the gasket was seeping oil along the bottom of the cover. It did this for a couple more rides, and then stopped. Total oil loss was maybe 1/4 oz. Do these kind of gaskets have to "seat" themselves sometimes? I followed proper torque sequence and specs.
Old Aug 31, 2010 | 02:36 PM
JRK5892's Avatar
JRK5892
nope sounds like you have a bad gasket or the torque is off, i made my own gasket after CNC the derby cover out or cork board and if it is not snug up on there it will leak. i would say pull it off and make sure that it was in there right, then snug it back up
Old Aug 31, 2010 | 03:57 PM
srshaw's Avatar
srshaw
If its not leaking now, I wouldnt worry about it if only a small amount of oil was lost. If its torqued ok, the only thing that might cause a problem if it was put in the wrong way round. The red writing on the gasket should face the clutch, away from the cover.
Old Sep 1, 2010 | 10:07 AM
dFREDb's Avatar
dFREDb
It's the large gasket that goes around the perimeter of the primary cover. I guess I'll just keep an eye on it cause that sucker is $30.00!
GROWLNTA
Feb 19, 2016 08:56 AM
urleycay
Apr 24, 2010 04:08 PM
Nautilus
EVO
13
Apr 7, 2010 01:41 PM
faber
Oct 5, 2008 08:53 PM
mjaw
EVO
May 28, 2008 10:26 AM
