Tear it down & go again..
Old Sep 7, 2010 | 01:41 PM
JCK's Avatar
JCK
Default Tear it down & go again..
Ive decided Ive had fun with my bike all year. So Im going to tear it down an go again. Have wolfgang do the heads.. Put in a woods high lift cam.. And ride like Im stupid. Get rid of the Andrews 54 H an the big Boyz heads and go again.. Now aint this just alot of fun..
Old Sep 7, 2010 | 01:57 PM
nevil's Avatar
nevil
I can tell you had this big grin on your face when you typed your post. Have a great time and be sure to let us know when you're done. Sounds like it should have even more whoop ***.
Old Sep 7, 2010 | 02:11 PM
paul s's Avatar
paul s
Did you have your crank done? Wolfgang heads and high lift Wood cams will be Big power for sure.
Old Sep 7, 2010 | 02:37 PM
JCK's Avatar
JCK
screw the crank.. have low numbers on it.. so ride it till I blow it up.. LOL I did think about it. But if I did that it would be a 124
Old Sep 7, 2010 | 02:48 PM
paul s's Avatar
paul s
That's cool, you can put it to the test for us. What cams are you lookin at?
Old Sep 7, 2010 | 02:49 PM
JCK's Avatar
JCK
woods said 408-6 Wolf said lets look at the 9s.. so still in the process..
Old Sep 7, 2010 | 02:52 PM
07 dyna man's Avatar
07 dyna man
are going to address the deck height issue, im still wating on the heads so i checked mine, and it was 0 thank god,
Old Sep 7, 2010 | 02:58 PM
JCK's Avatar
JCK
yes .. Im changing piston to CPs and going to 11.1 comp..
Old Sep 7, 2010 | 03:04 PM
07 dyna man
its addicting isnt it, when i did the big bore i said i was done, lol now its apart again doing the heads and a cam swap
Old Sep 7, 2010 | 03:11 PM
leeinmemphis's Avatar
leeinmemphis
For the last year I have been running a 103 with 54h gear drive cams and big boyz heads. It put out 103/113 and runs really good but I was always worried about my crank. I put 10k miles on it and decided that was enough so I took it to a shop and it is currently tore down. Everything I've read is anything over 100hp you are asking for trouble on the stock crank.
My fatbob has a welded/trued/balanced oem crank but the Ultra is getting an s and s crank.
Good luck. I hope you have the same good luck that I did but realize there are alot of people that have bet on it and lost.
