Check your muffler bracket bolts
Old Sep 11, 2010 | 07:44 PM
doxbike's Avatar
doxbike
Default Check your muffler bracket bolts
Started the beast ('09 FXDF, 13K miles) up a few days ago and did the usual walk-around while gearing up. I noticed the muffs were moving around more than normal. Seems the bracket mounting bolt had sheared off and the 2 attendant studs had vibrated in their holes so much, they reamed out the entire holes. The case was cracked at the bolt hole and the bracket had nearly worn thru the side cover. Warranty is fixing all, but good idea to check yours!
Old Sep 11, 2010 | 07:57 PM
pcbunn's Avatar
pcbunn
I'm hoping everyone uses Loctite every time they install something. I have become a Loctite addict!
jakson200369
May 30, 2016 02:30 PM
fadedbuddha
Oct 10, 2014 05:39 PM
monster715
Mar 18, 2014 10:09 PM
fabrik8r
Oct 2, 2011 01:45 PM
live4rut
Sep 18, 2010 09:00 PM
