Screaming Eagle Heavy Breather Install
Old Sep 16, 2010 | 09:55 PM
code1's Avatar
code1
Default Screaming Eagle Heavy Breather Install
I was installing the screaming eagle heavy breather kit on my 2010 Fat Bob and when removing the stock air cleaner I notice there was a small plug/wire attached. The new heavy breather air cleaner has no spot I can see for it is it fine to leave it unattached?
Old Sep 16, 2010 | 09:57 PM
bberck's Avatar
bberck
Its a sensor used on european models, just zip tie it up out of the way.
Old Sep 16, 2010 | 10:11 PM
code1's Avatar
code1
Default great
Great news! I was wondering if I had a problem or not I installed the heavy breather and tear drop cover it wasn't to hard but I keep looking at the sticking wire hanging there.
Old Sep 17, 2010 | 01:09 AM
kk6pg's Avatar
kk6pg
Thats a relief. And here I thought something else done fell off the bike
Old Sep 17, 2010 | 01:33 AM
Foxster's Avatar
Foxster
I think you are going to need the eliminator plug for that otherwise the ECU will still be reading the sensor and thinking there is low air flow and adjust the mixture accordingly. I needed it when I did the stage-1 on my UK bike.
Old Sep 17, 2010 | 08:16 AM
code1's Avatar
code1
I have did some reading and my understanding is the without installing a eliminator plug you could have some ECU trouble codes show up time to time. I might go ahead and order one just to be safe does anyone know where to buy one?
Old Sep 17, 2010 | 12:52 PM
ratt196635's Avatar
ratt196635
You only need it if you have a European bike in the US its not needed. just tie it up out of the way and ride ride ride
Old Sep 17, 2010 | 01:02 PM
code1's Avatar
code1
I tied it up and rode for a hour this morning engine runs smoother than it did with the stock air cleaner. I am not seeing even adding the down load right now the way it runs why even mess with anything is my thought. Thanks for rhe help!
Old Sep 17, 2010 | 01:07 PM
Grendel4's Avatar
Grendel4
Do you have aftermarket exhaust or have you removed the catalytic converters or changed your exhaust in any way?
If you have, you need to re-think your tuning options, IMHO. And also, if you have, you seriously need to reconsider if you were thinking a dealer 'download' will help you.
Old Sep 17, 2010 | 02:25 PM
code1's Avatar
code1
I have the screaming eagle exhaust and my bob would shake a whole lot since I have owned it. Today after the HB install it runs smooth.
