JS Lift and lowering blocks
Old Sep 19, 2010 | 08:13 AM
yandeltx's Avatar
yandeltx
Default JS Lift and lowering blocks
If I install 1" lowering blocks on my lowrider does anyone know if it will create any issues with be getting the lift under my bike? Also, when I have the lower part of the shock loose from the swingarm, whould that be the time to adjust the shocks or do they need to be attached on both ends to adjust. Sorry for the elementary questions.l
Old Sep 19, 2010 | 12:37 PM
SC-Longhair's Avatar
SC-Longhair
Do you already have the lift?
Adjust the shocks while installed.
Old Sep 19, 2010 | 12:53 PM
SC-Longhair
I would assume you went to the J&S website where they list the specs of the jack.
You may or may not have missed this one:
Minimum lift height 4”
If you're bike's ground clearance is less than that with the lowering blocks then yes, you will have a problem.
Old Sep 19, 2010 | 02:01 PM
yandeltx's Avatar
yandeltx
I already have the lift. I was just wondering if I jack it up, install the 1" lowering blocks, will have an issue getting it off the lift and the lift out from under the bike. I probably better have some one handy to help me just in case.
Old Sep 19, 2010 | 05:46 PM
JaronB's Avatar
JaronB
I don't see why it wouldn't! I got about an 1" to 1.5" sitting on the jiffy. I'd say worse case you have to put a 2x4 under the jiffy to sit the bike straight up!
+1 on adjust installed. I'd get a spanner wrench to make it easy!
Old Sep 19, 2010 | 05:48 PM
Iceman24's Avatar
Iceman24
Ditto - might have to block the stand. I know mine just fits under the FLHX w/little room to spare & it's not lowered.
P_RsBO
Dec 29, 2013 01:20 PM
Jmbeebe0722
Sep 16, 2013 04:35 AM
Shrug
Dec 26, 2012 10:55 PM
coachstorms
Oct 14, 2011 08:56 PM
jharp
General Topics/Tech Tips
Nov 19, 2006 10:20 AM
