Heavy grease on the kick stand
Old Sep 20, 2010 | 05:50 PM
iseerock's Avatar
iseerock
Stage III
Default Heavy grease on the kick stand
So I went on a ride the other day on my 99 dyna wide glide and when I got home and put the kickstand down I noticed some heavy grease on my kickstand. I thought maybe it was something I ran over and splashed up on the bike, like tar. After more of an inspection there was no other grease on the bike and it looks like its coming out of the front sprocket of the drive belt. There is nothing leaking on the ground at all. It was about a 70 mile ride as well. Is this normal or is this a big problem?
Thanks
Old Sep 20, 2010 | 06:02 PM
JRK5892's Avatar
JRK5892
yep when my inner primary failed that happened! could also be the shifter shaft seal
Old Sep 20, 2010 | 06:06 PM
Sumpnut's Avatar
Sumpnut
+1 on the inner shifter shaft seal
Old Sep 20, 2010 | 06:16 PM
iseerock's Avatar
iseerock
Stage III
Dang, how fast is this thing going to go bad? Is this something I should get fixed today? Is it as slow a leak as it looks?
Old Sep 20, 2010 | 06:33 PM
Sumpnut's Avatar
Sumpnut
I had that prob.. had forwards fitted and after 2 years oil started leaking out of the chrome cap thats fitted in the primary cover where the gear shaft used to be...then it started leaking at the rear.. the gasket had slipped and needed to be changed..primary cover has to come off..takes a dealer 20-30 mins to do if thats the prob and if they fitted the forwards they should do it free of charge under warranty.
Attached Thumbnails Heavy grease on the kick stand-sbsweden-090.jpg   Heavy grease on the kick stand-sbsweden-115.jpg
Old Sep 20, 2010 | 08:03 PM
dsiltman's Avatar
dsiltman
When I did the forwards on my lowrider I cut the arm off of the shifter shaft and stuck it back in behind the plug to keep that little gasket in place, and it keeps crap from getting in that tube from the backside.
Old Sep 20, 2010 | 08:05 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It was the quad seal that did that for me.
Old Sep 20, 2010 | 08:42 PM
iseerock's Avatar
iseerock
Stage III
Ride on, thanks for the help. I am probably looking at taking it in if its a 20-30 min fix there. I will have to let you know what happens.
Old Sep 20, 2010 | 08:46 PM
dFREDb's Avatar
dFREDb
Better have them check the main shaft bearing. Same symptoms and I had to have a complete trans rebuild under warranty.
GalvTexGuy
2014-2024 Touring Models
11
Aug 20, 2019 08:35 PM
landslide03
May 24, 2012 06:47 PM
scootnshoot
EVO
Mar 6, 2012 10:17 AM
EasternSP
Mar 27, 2011 09:05 AM
hotrod351
Exhaust System Topics
Sep 22, 2006 08:57 PM
