Question about 2 into 1 pipes
Old Oct 14, 2010 | 11:26 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Any 2 into 1 should stomp all over your stock exhaust with a tuner, hi flow filter and good tune. Once you put all that on you will ask yourslef why you waited so long.
Drew
Old Oct 14, 2010 | 11:34 AM
editbrain's Avatar
editbrain
Originally Posted by dirt_dobber
I love the way my ---Vance & Hines Pro Pipe HI-OUTPUT sound and perform (except they are very hot against the leg (I have ordered the wrap)
this note below is from their product page:
Pro Pipe Hi-Output is a purpose-built addition to the Pro Pipe family of 2-into-1 exhaust systems. Every aspect of Pro Pipe Hi-Output’s design is singularly focused to yield maximum horsepower by improving the volumetric efficiency of heavily modified engines.
After countless dyno tests Pro Pipe Hi-Output was built utilizing tuned length headers that step from 1-3/4” to 2-1/4” to optimize exhaust gas velocity and scavenging while also maintaining the perfect balance of exhaust back pressure, assuring crisp throttle response and maximum roll on power. In addition, the merge collector features handcrafted internal knife edging to further improve scavenging efficiency through the collector.
Following the collector, the megaphone immediately tapers out to a 3-1/2” muffler body that expands to 4 1/2” for increased baffle area. Our exclusive Vance & Hines baffle features reverse cone engineering that allows maximum power yet omits the perfect exhaust note rumble for any hi output motor. Keeping its focus on performance, Pro Pipe Hi-Output retains the signature cues of the Vance & Hines Black Line with its high temperature ceramic coating and contrasted machined billet end cap.
Keep an eye out where the muffler meets the head pipe. It will not be long until you get hot gases blowing up your leg. I bet if you go out now, you can wipe your finger on top of where the flange is located (where the muffler meets the head pipe), and you will have carbon build up. I had to return mine because of the bad design. V&H customer service recommended fix was to use Gasket Maker paste. BS.. Not for a near $1000 pipe. Just an FYI.
I replaced the Hi-Output Pro Pipe with a Thunderheader, and it yielded better HP and better Torque.
Old Oct 14, 2010 | 11:40 AM
bigdaddy33's Avatar
bigdaddy33
Give the D&D Fat Cat a look. If you like the appearance, I'm certain you'll like the performance and quality.
Old Oct 14, 2010 | 04:07 PM
paul s's Avatar
paul s
I don't think the difference is that much from one system to another, a 2-1 will give you a little more on the bottom but it isn't anything like most describe. I had V&H Sideshots and lost a few ponies going with my Supermeg, I had to add the open cap to get it right. My 08 did have cats in them.
Old Oct 14, 2010 | 07:22 PM
dope_man_21's Avatar
dope_man_21
This is what I am looking at (IF I ever win the lottery)
http://www.rbracing-rsr.com/lsrprostock.htm
NPoulos24
Sep 1, 2015 08:19 PM
Glen88
Exhaust System Topics
Aug 23, 2014 06:26 PM
Reaper7534
May 26, 2013 03:35 PM
AdrianVall
Mar 31, 2009 08:37 PM
CCCLASSIC
Sep 21, 2008 12:00 AM
