Rear brake chatter... frame flexing?
Am i crazy? I've checked the frame for stress cracks, brakes, etc.. and found nothing.. I mainly use my front brake while slowing. It's not that big of an issue (as long as it's not hurting anything). I tried searching different brake terms and came up with nothing that matches what i'm talking about. Just want to make sure i haven't over looked something.
Thanks for the help
Nathan
Yeah i don't believe its a warped rotor. It's doesn't have the grab/release going on. If you've ever locked up antilock brakes on a car/truck and felt that chatter. That's the best i can compare it to but it feel like its right under you butt. You can actually feel the frame flex in the middle.
Having forward controls, coming to a light i see changing. I may just flash the brake light with the rear brake. Then slow using just the rear, most times when i get to the light it's green. However i noticed if you give it more brake it chatters, flexes. Like you can feel the rear shocks flex.
Not like i do it all the time but since i have noticed it i've tried to figure out what causes it. Were not talking braking and locking up rear tire. Just under heavier braking.
I tend to use my front brake and rear together but there are times where i may use 1 or the other, not both.
Bikerlaw, doesn't feel like metal to metal or sound like it. But i'll have to see if i can do it again to be sure.
Also it's never done it under normal or hard braking using both brakes. I could take it in and have them take a look... It's just a pita. Honestly i'd rather fix stuff myself. Yeah i have a warranty but i'm not running my bike to the dealer over every little thing... Some of the things i would have questioned are normal... Like harley's being noisey. After riding a few days i was thinking man this motor sure is loud... after searching and riding a bit i find out it's normal noise.. nothing others don't have.
Thanks for the help
Nathan
