Can you do a quality powder coat chrome?
Old Oct 20, 2010 | 04:33 AM
jakedietz's Avatar
jakedietz
Default Can you do a quality powder coat chrome?
If so is the chrome stripped first? I want to know because this afternoon I'm heading to the local powder coater and I would like to know the process to make sure its a quality job, thanks!
Old Oct 20, 2010 | 06:39 AM
Jarhead08's Avatar
Jarhead08
To do it right you'll have the chrome sanded off. Only way to get a good finish on the powder
Old Oct 20, 2010 | 06:45 AM
jakedietz's Avatar
jakedietz
Ok, so being sand blasted first would work?
Old Oct 20, 2010 | 07:04 AM
U-234's Avatar
U-234
Since the question is about PC you will prob get an answer from JRK. Most of the black on my Shovel is PC. Some done over chrome. The PC place will bead blast and then coat. No probs over good quality chrome. If chrome is peeling then it should be removed.
Old Oct 20, 2010 | 07:08 AM
LoveHate's Avatar
LoveHate
No problems powder coating is on the chrome. Even having two corrosion protection.
All parts on my bike are painted on chrome ... I have some experience
Old Oct 20, 2010 | 07:10 AM
LoveHate's Avatar
LoveHate
Originally Posted by U-234
...If chrome is peeling then it should be removed.
This is very true and important
Old Oct 20, 2010 | 07:37 AM
1bad09sglide's Avatar
1bad09sglide
I use to run a powder coating shop that did custom work and the process we used was to get the part from the customer, bake it for 8 hrs to get oils out of the metal, sandblast, rinse, heat parts based on size and type of metal, aplly powder then bake on and let cool. If it is a good shop they should use the same process or very similar. Yes you can powder coat over chrome as long as its done correctly and you will have no problems.
Old Oct 20, 2010 | 07:41 AM
blacknsilver's Avatar
blacknsilver
All the parts I have had done so far by the coater I use has blasted them first.
Old Oct 20, 2010 | 07:48 AM
risdo's Avatar
risdo
I had my stuff bead-blasted before I painted it. Cost me about $40 for the slip-ons and the heat shields. Worked great. The paint on my slip-ons is about three years old, and still looks perfect (except for my boot marks)
I live in a furniture town, so there are small finishing shops all over the place here.
Old Oct 20, 2010 | 08:13 AM
tomt's Avatar
tomt
I'm doing a complete redue of my scoot, a winter project. Relocating my speedo and tack. New tank, fenders and paint. The first part is done, the chrome dash in matt black.
Chrome dash was coated by The Powder Pro, I got it back yesterday. They sand blasted the part first. It came out perfect. Thanks to Joe and his partner Sean.
Here are photos of the dash and all the components back in.
