KickStand MOD ???
Old Oct 21, 2010 | 11:15 AM
JRK5892's Avatar
JRK5892
by the way your bike looks GREAT!!!!
Old Oct 21, 2010 | 12:28 PM
bearhart's Avatar
bearhart
any info is helpful, i need this too!
Old Oct 21, 2010 | 03:32 PM
panic_fan's Avatar
panic_fan
Originally Posted by 08fxdf43202
Remove the jiffy & remove material from the top of the locking tab.
I used a sanding disk on my 4" grinder... scribe a line on the tab & sand away.
After a test fit I noticed that the factory weld was obstructing a
'full seating' of the tab into the frame location... so I sanded a little of that away as well.
I did exactly the same thing and also noticed that a bit of the weld kept it from seating completely. You don't have to grind much off the kickstand. I think I took off about 3/16".
Scariest part was getting it off the lift when I was done. In order to get the lift under the bike after I lowered it I had to ride the bike onto a couple pieces of stacked plywood under the front and rear wheels. So when I let it back down onto the plywood with the "lowered" kickstand it REALLY leaned over. I think a little poop came out...
Old Oct 21, 2010 | 06:15 PM
Sumpnut's Avatar
Sumpnut
I lowered my SB front and back with progressives..bike was too upright on the stand but did the cheapo mod with the kickstand like this...
Found the link
https://www.hdforums.com/forum/dyna-...step-pics.html
But I did'nt need to touch the frame..bikes now back to normal lean..
Just a footnote*** don't know if when you do an oil check without the lean the measurement reads wrong ???
Old Oct 29, 2010 | 08:23 PM
NuTTSaK's Avatar
NuTTSaK
Did the MOD, worked great, Thanks for all the responses.
Old Oct 30, 2010 | 03:15 AM
==ShaDoW=='s Avatar
==ShaDoW==
do you have a sledge hammer just beat it some till its at the right angle,
Old Oct 30, 2010 | 08:05 AM
Mk1Racer's Avatar
Mk1Racer
Can't offer anything for the kickstand, but just wanted to say that you've got a really nice looking bike.
CACruiserHD
Aug 18, 2014 04:23 PM
FXDXJimmy
Apr 19, 2012 05:58 AM
LX HEMI
Nov 13, 2009 02:42 AM
A-10 KChawg
Apr 30, 2009 11:13 PM
69sport
Ironhead
Jun 16, 2006 10:51 AM
