Fat Bob Forward Control Extensions.
Old Oct 20, 2010 | 09:49 PM
oeberg's Avatar
oeberg
Default Fat Bob Forward Control Extensions.
I really love my FB. But the thing is that is feels to cramped up. I need more legroom and further reach.
The forward controll extentions I have found online states that they won,t work with stock exhaust headers. Now one of the reasons I like the look of the FB is the exhaust system. Is there any aftermarket provider that have a solution for this? Or anyone in here that have found their own solution to get around the exhaust headers? I know there is seats out there that will move you back an inch or two but I just spent over a G on a seat set-up that I really like and would rather find a solution that put me "forward" instead of "backward".
/Fred
Old Oct 20, 2010 | 10:06 PM
dustinn3's Avatar
dustinn3
I put the Kuryakyn 3 inch extensions on mine before I changed out my exhaust and they fit just fine. The warning on the Kuryakyn's only applies to 2010's. Only problem was it put my leg right along the stock exhaust and it hits the stock AC as well. I got tired of the heat so I changed out pipes. AC is next.
Old Oct 20, 2010 | 10:15 PM
wmo777's Avatar
wmo777
I have 3" extensions on my FatBob, and found a way to put them on with the stock exhaust. Just mount the left peg bracket on the inside of the extension. Then the brake rod does not hit the pipes. It takes some fiddling around, but does work, as evident in the attached pic. You can see it fairly well. Having the footpeg about an inch to the left doesn't bother me at all.
Old Oct 20, 2010 | 10:20 PM
blacknsilver's Avatar
blacknsilver
Here is a link to the Kuryakyn 3" extension. Migh find them cheaper somewhere else.
http://cgi.ebay.com/ebaymotors/KURYA...item58887d0c5b
Old Oct 20, 2010 | 10:28 PM
oeberg's Avatar
oeberg
Yeah....that is part of my problem....mine is a 2010
Old Oct 20, 2010 | 10:31 PM
oeberg's Avatar
oeberg
Thanx for inputs. I'm gonna check with kuryakyn and see if there is any way to work around the problem.
Old Oct 22, 2010 | 03:47 PM
NighthawkFXDF's Avatar
NighthawkFXDF
Stage III
Let us know how it works out! I have a 2010 and am looking for some extra legroom too!
Old May 24, 2012 | 12:37 PM
cuda918's Avatar
cuda918
Stage II
Default Need a work around for 2010 Fat Bob forward extension
wmo777, can you post some pics at a better angle with more light so we can see exactly how it looks with your setup? I have a 2010 and want the extensions but need a work around. anybody else have a solution?
Old May 24, 2012 | 04:19 PM
70copperz's Avatar
70copperz
Check these out if you don't want to spend much, this will be my next purchase.
http://www.jpcycles.com/product/540-...5&zmap=540-864
Old May 25, 2012 | 11:40 PM
twister2gt's Avatar
twister2gt
drag specialties makes a 2" kit for $100 dollars says on there website that it is for there forward control kit but i used them on my HD control kit on my street bob. I'm 6'3 and 2 inchs makes it so much more comfortable don't think i would want to go out any more. If you get this kit run your stock bolts down the threads of the plates or run a tap down them to clean up the threads i don't think they do this after chroming them i had a bolt get stuck in them and had to cut it off and put in a vise so i just used my stock hardware to mount the control to the plate. My stock hardware had thread cleaner on the ends.
