Exhaust comparison..
Old Oct 23, 2010 | 06:46 PM
lhcstreetbob's Avatar
lhcstreetbob
you should love the thunderheader man..ive ran mine on the bike stock, with andrews 54h cams and now with the 103. it really came to life with the cams and big bore kit ...
Old Oct 23, 2010 | 06:50 PM
Vinsil's Avatar
Vinsil
No headwork? I really want to do the cams/headwork at the same time to just pay the dyno once....but it sure would be awesome to do this in stages.
Are you happy with the 54's? I'm leaning really hard toward those, the 7H's or the Tman 590's.....
Old Oct 23, 2010 | 07:02 PM
lhcstreetbob
thats what i did .in stages i wanted to know what made the most difference (i think the cams) i like the 54s alot they pulll very hard and i love the way the thunderheader sounds with them ...but im already looking for more tho Lol heads or a bigger cam..
Old Oct 23, 2010 | 07:15 PM
Vinsil's Avatar
Vinsil
Awesome. Well...if you yank the cams, hit me up! Some savings on a used set will sway my choice!
From what I've read...the cams/headwork are supposed to make the most difference so I figured I'd start there and when it needs more, go with a BB kit and larger cam. Damn addicting I tell ya.
Old Oct 23, 2010 | 07:27 PM
lhcstreetbob
the big bore is pretty straight forward i wish i would have just done the 107 tho b/c i already want more ...if you take the heads off your only a few bolts from having the jugs off....
Old Oct 23, 2010 | 08:20 PM
mentor70's Avatar
mentor70
If you decide on the Tman .590s, hit me up, I have a new in box set for GD, ill give you a great deal. and pay shipping.
Old Oct 24, 2010 | 02:32 PM
Denny69's Avatar
Denny69
Originally Posted by jpace024
I was asking what you are looking at on the sheet to tell if it was slipping wiseazz. It does feel like it slips under hard acceleration though.
As far as the tune goes, I dont know what youre getting at, but it runs perfect. Pulls hard all the way to redline, no decel pop, night and day difference from motor without cams and dyno. If it didnt have the power, I wouldnt think the clutch would slip as you say it is....right?
Sorry, wasn't rying to be a wiseazz. You will probably feel it in 2nd gear. When a clutch is strong, and holding, your curve is overall consistant. When it is consistantly deviating, it shows a clutches inability to hold torque. Oh, and yes, if you didn't have the power, your clutch would not slip unless abused ie. doing burnouts, wheelies or both. An easy fix is a variable pressure clutch. Again, not trying to **** anybody off here.
Old Oct 24, 2010 | 02:42 PM
Faast Ed's Avatar
Faast Ed
Originally Posted by red devil
My buddy has a TH on a stock fatboy, and it kinda reminds me of my piped(LRD)4 stroke honda 450r. I'm not saying that it will sound like a honda, but I think most people that know what I'm talking about will agree. My quad has been called the "chopper in the woods" and sounds pretty bada$$! Don't forget when you do any motor work, the overall sound of the exhaust will change.
Good point about a stock bike. While my Fatcat took some getting used to, "different sound",...... I've heard one on a stock motor that embarrassed me for the guy. A performance pipe often sounds like **** on a stock motor. Once he gets his cams and gets his compression up, he'll likely like the sound.
To me, 2 into 1's indeed sound "different" and take some getting used to.
But after getting used to it, they sound so "sporty and racey" that it ain't a bad thing at all. But ya gots to have a motor that'll compliment the pipe.
The standard Rienhart 2 into 1, is likely the lowest rated 2 into 1 out there (no offense to anyone). They sound good and improve performance, but not as good as many other 2 into 1's.
Now the Bub 7, 2 into 1 is a high rated pipe (go figure). Way better made than the traditional rienhart 2 into 1. Nice looking too!
I like my Fatcat, but there are others that are just as good and might even sound better. I have no regrets running this pipe though.
Old Oct 24, 2010 | 02:48 PM
Faast Ed's Avatar
Faast Ed
Originally Posted by Denny69
Are these "controlled" numbers? I also notice your clutch slipping a bit. Have gone with a pro clutch yet?
That didn't look like clutch slip to me. Smoothing number wasn't present, but I'd bet it was set low on those passes. The effect was too consistant along the entire curve. Clutch slippage don't do that.
Old Oct 24, 2010 | 02:54 PM
Faast Ed's Avatar
Faast Ed
Clutch slip example. Notice the smoothing is set to "5", which smoothes out all the little bumps.
