Burly Slammer Kit issue/ question
Old Oct 26, 2010 | 11:10 AM
83efi's Avatar
83efi
Default Burly Slammer Kit issue/ question
I just installed a Burly Slammer Kit front and rear on my 2010 Street Bob. As expected, it rides stiffer then before. What I didn't expect is with the spacers cut at 1" as recommended by Burly, the front end bottoms out and only has 3/4 of an inch to compress. I called their tech. support and the guy pretty much said it was to be expected, that is normal and I should lengthen the spacer. If I lengthen the spacer, it will bring the bike back up. So my question is, for folks on here who have the slammer kit installed, what length spacer are you using and how much compression in the front end does that allow? Does the front end clunk and bottom out with the 1 inch spacer like mine? Thanks.
Old Oct 26, 2010 | 11:19 AM
bikerlaw's Avatar
bikerlaw
Last year I installed progressives drop in kit and it was bottoming out as well. It would take quite a hit, but it would bang on occasion. I switched to Harley's heavy weight fork oil and the problem was greatly improved.
Old Oct 26, 2010 | 06:46 PM
83efi's Avatar
83efi
Thanks for the info. Anyone with one of these kits had a similar experience?
Old Oct 26, 2010 | 10:53 PM
parts eeter's Avatar
parts eeter
If you are gonna lower any forks heavier fork oil will be required to maintain a manageable ride. Notice I didnt say good ride,just manageable. If I lower my 49mm Street Bob forks I am gonna use 20 wt fluid. Most guys use Screamin Eagle 15wt. I weigh 265 so I figure 20 will do the trick.
Old Oct 27, 2010 | 07:15 AM
dpriest's Avatar
dpriest
i did the progressive 2" drop with the screamin eagle oil, and there is no bottoming out of the front end. the ride is stiff though. progressive recommends you try different wt. oils until you find the one thats right for you.
Old Oct 27, 2010 | 08:02 AM
unskilled's Avatar
unskilled
Could it be that by pulling out the original springs you lost a lot of oil?
I let them drip for a while so I didn't lose too much of the fork oil. I still need to put in some new oil, but so far, no bottoming out on the front end with the Burly kit.
Old Oct 27, 2010 | 11:36 AM
83efi's Avatar
83efi
I let them drip for days and didnt add any oil. Looks like im going to change the oil now. Thanks for all the input guys. And dpriest, love that bike!
Old Oct 27, 2010 | 05:41 PM
lhgdale's Avatar
lhgdale
Keep us posted, I am planning on getting the slammer kit for my wide glide in a few weeks. I definately don't want my bike bottoming out!
Old Oct 27, 2010 | 06:48 PM
parts eeter
Did you use the drop in kit or the kit that used extra top out springs on the damper rod?
Old Oct 28, 2010 | 01:04 AM
Le Vizir's Avatar
Le Vizir
Nice idee lhgdale..!
I don't know how the ride is after, but the look is terrific..!!!
Look this one :
(Sorry it's not mine..But soon as possible for sure..I take it in the Burly's fB profil)
