Cable attached to stock exhaust?
Old Oct 29, 2010 | 08:22 PM
stbobau's Avatar
stbobau
Default Cable attached to stock exhaust?
Hi all,
removing stock exhaust from 2011 street bob. It has a cable attached to it.
Can i remove this cable completely? What do i do with it?
Cheers
Old Oct 29, 2010 | 08:26 PM
jaysbobber's Avatar
jaysbobber
Those are your O2 sensors I believe. You need them.
Old Oct 29, 2010 | 08:29 PM
stbobau's Avatar
stbobau
Cheers Jay,
not the sensors, there is another cable that runs from below the seat to the pipes where the header pipes meet the mufflers. Not sure what it is
Old Oct 29, 2010 | 08:36 PM
jaysbobber's Avatar
jaysbobber
I didn't see that wire on mine when I took the mufflers off. Is your bike a California bike, or a International bike? They are different than my bike I believe which is a 49 state.
Old Oct 29, 2010 | 08:40 PM
stbobau's Avatar
stbobau
Australia
Old Oct 29, 2010 | 08:44 PM
jaysbobber's Avatar
jaysbobber
I got nothing for you on that one. Sorry. They may have some emissions thing that mine doesn't have. Good luck. Have you phoned the dealer? You may want to give them a call if you don't get an answer here.
Old Oct 29, 2010 | 09:03 PM
stbobau's Avatar
stbobau
cheers
Old Oct 29, 2010 | 09:20 PM
NoLongerAmember's Avatar
NoLongerAmember
Active Exhaust control, only on overseas models. H-D says it is to enhance performance, but I think it is to quiet the bike at idle and cruise. The more throttle you give the more the valve opens. It is only located on the bottom muffler. You may need to remove the cable from the module.
CB
Old Oct 29, 2010 | 09:29 PM
soft 02's Avatar
soft 02
Could it be like those flaps in old smog vehicles to raise the engine temp faster when its cold. more eficiant than choking it. just a thought.
Old Oct 29, 2010 | 10:53 PM
Tech23's Avatar
Tech23
cbz1200n, From what you describe it sounds very similar to Yamaha's EXUP system. VW uses a similar system on the VR6 AWD GTI
http://www.snowmobile.com/products/i...aust-1178.html
I was not aware that overseas HD's had an exhaust device like this. It is used to to enhance low end (with more back pressure) and opens up the exhaust flow for better top end. The best of both worlds. Something like drag pipes without the negative effect on low end torque.
Tech23
