High beam stuck on
Old Nov 5, 2010 | 01:56 AM
brenth's Avatar
brenth
Default High beam stuck on
Turned the bike on tonight and the high beam rocker was on, so I went to turn it off, and no matter which postion I put it in, the light doesn't change, and the indicator does not go off. The high beam is on. Anyone know how to fix it?
Old Nov 5, 2010 | 05:01 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Do you own a voltmeter?
__________________
www.Captain-Itch.com
Old Nov 5, 2010 | 06:19 AM
grbrown's Avatar
grbrown
Wink
It could be as simple as one filament inside the bulb has broken, but stuck itself to the other filament. Check the bulb closely, you could just need a new bulb. Don't look at the bulb closely while it is lit, as two filaments lit up together are impressively bright!
Old Nov 5, 2010 | 10:58 AM
Black Bart's Avatar
Black Bart
Could also be the contacts inside the rocker switch being closed all the time for the high beam. Get a meter and read it out to make sure that the contacts are breaking when when you move the switch to low beam position.
Old Nov 5, 2010 | 01:07 PM
kk6pg's Avatar
kk6pg
Had the same issue arise on a friends bike. Turns out the ground wire in the harness had broken and the path was from the bucket through the forks and to the frame via the neck bearings. Ran an external ground from the bucket/forks to the frame and the light returned to normal.
Go figure...
I'm not saying this has happened to yours, but its something to think about
Old Nov 5, 2010 | 01:11 PM
grbrown's Avatar
grbrown
Talking
Go figure...
Having owned MZ 2-strokes that makes a lot of sense!
Chris Topple
Electrical/Lighting/Alarm
Feb 11, 2020 11:21 PM
tcastle64
Jul 31, 2012 07:22 PM
DPete
Feb 27, 2011 02:38 PM
FUQUA
Feb 8, 2010 06:45 PM
brickie
Jun 5, 2009 11:51 AM
