Winterizing Tips Needed
Old Nov 7, 2010 | 11:56 PM
bobgv's Avatar
bobgv
Default Winterizing Tips Needed
Whats the best way to prepare your bike for storage in a cold a$$ garage and how do you stop your FB rims and chrome from pitting. Those rims are a pain in the a$$ to keep clean.Thanks for the help in advance and ride safe.
Old Nov 8, 2010 | 12:29 AM
Jarhead08's Avatar
Jarhead08
Fill your tank full and add fuel stabilizer. You can polish up your rims with mothers or other may Polish. I use neverdull to clean my bike. I use it on everything from paint to powdercoat to chrome. You just don't want to get it on the black of the motor or tires. Takes a bit to wear off those places. It doesn't scratch your chrome, it helps protect from water spots, it turns greyishish white so its easy to see if you miss a spot when cleaning. You could also remove your battery and keep it indoors and plug it into your tender to keep your battery life at a maximum. This is what I do.
Old Nov 8, 2010 | 05:33 AM
Krazy8s's Avatar
Krazy8s
+ 1 on the above. The only extra I do is throw a sheet over the bike to stop dust and whatever other crap that may settle on it if uncovered.
Old Nov 8, 2010 | 05:53 AM
Iceman24's Avatar
Iceman24
Don't forget to dump/change fluids & run motor for ~5min w/stabilizer (vs. just putting in tank). I also add oil into cylinders & turn over and elevate bike on lift to take weight off suspension & tires.
You can read long-term storage steps in HD owners manual, as a reference.
Old Nov 8, 2010 | 06:51 AM
bobnehoc's Avatar
bobnehoc
Do what I do....Just keep riding ....I have never winterized any of my bikes as I ride all year, weather and road conditions permitting of cause. But the earlier responses to your post is what I would do if I wasn't going to ride. Can't imagine not being able to ride for that long a period...
Old Nov 8, 2010 | 07:45 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
First wash your bike and get all brake dust off the wheels. Dry completely .
1. full tank of gas with stabil fuel stabilizer (run 5 minutes)
2. battery tender
3. oil & filter change
4. over inflate tires 2-3 lbs.
5. breathable MC cover
6. some people spray wheels with boeshield (I don't)
No need to start it until Spring if you don't ride it.
One note: A cold garage is better for storage than heated as the lower the temperature the slower corrosion sets in.
Also, remove any yard fertilizer, pool chemicals or rock salt from your garage before storing as they are all highly corrosive
Old Nov 8, 2010 | 08:18 AM
rmatt34's Avatar
rmatt34
And for God's sake , don't forget to kiss it goodnight !!!
In all seriousness,
CHANGE YOUR OIL... YES, WHEN YOU PUT IS AWAY NOT WHEN YOU START IT AGAIN IN THE SPRING...(well, unless you do both.)
But why would I do that ?
I'm glad you asked...
used oil is actually acidic and corrosive ...! so don't let it sit in your bike all winter..
Old Nov 8, 2010 | 12:50 PM
bobgv's Avatar
bobgv
Default winterizing
Thanks for all the useful tips one thing about the oil change thing does it apply also to synthetic oil which is in the bike for a 1k already. Again thanks to all the forum members.This place is the best. Safe riding all
Old Nov 8, 2010 | 12:52 PM
rmatt34's Avatar
rmatt34
It applies to anything with a motor .... (internal combustion, of course...)
Old Nov 10, 2010 | 02:13 PM
crazy ray's Avatar
crazy ray
Up here in northern wisconsin the mice and squirels like to pack food in any dry part of your machine, even in the pipes.
