Welcome to the world of technology. To change the idle you have to get a dealer to do it with their computer, or install a tuner (unless there already is one on the bike) and do it yourself. If your bike is at the dealer for service they shouldn't charge much, many will do it for free.
If your metric that you are referring to is your 1998 YZF600 it's not EFI , it's carbureted with CVKD36 Keihins..
As far as why you'd want to (on a race bike anyway), setting your idle really high helps rear wheel hop and front end chatter when hard on the binders setting up for a corner... it helps the engine maintain RPM when clutching and downshifting and makes RPM matching easier...
and therefore faster lap times dude !
I dialed in some extra fuel on my 06 88incher with my Fuelpak to knock down the idle a bit. Sounds good now and more importantly idles cooler with the added fuel. Many tuners allow idle speed adjustment. However I have never been a fan of the almost stalling idle speed the carbed guys think is cool. The oil pump isnt pushing any oil to the engine like that.
Some of the HD FI bikes (the old M&M bikes in particular) have screw adjustments in the throttlebody. On other bikes they are hidden by a plug behind the face plate. Having explained that, DON'T try and adjust it like a carb. All that does is mess up the ECM and it may throw other settings out of whack. So if you want to play with the idle you need to get the tuning software and adjust it via a computer.
At least that's my experience.
Depends, the 08 and up touring bikes with TBW don't have external adjustments. The throttle plate is controled by the ECM, the only adjustment possible is thru the ECM. But your right, reducing the idle on an EFI bike is usually not a good idea.
Here we go again. Someone hears a few people say "you'll kill your engine with a low idle speed" and now they preach it to everyone else. If you don't let your bike idle for 15, 20 or 30 minutes at a time it doesn't make a ****. I guess that's why before fuel injection came out and most people had their bikes idling at around 5 to 600 rpm the engine would seize up if you let it idle for 5 minutes and all of the engines needed a rebuild after 1000 miles. Come on now. Good grief. The only major draw back to a very low idle is the load that is applied to the rod and crank bearings because of the slow revolutions.
lol! I wanted to be one of those cool guys on youtube that have idle real down low putt (2 seconds later) putt (2 seconds later) putt. Just kidding, was just curious?
