What exactly happened in 2006?
Old Nov 13, 2010 | 12:48 PM
lo-rider's Avatar
lo-rider
2007-up had fewer issues, but some of the latest models run hotter (because of EPA regs).
Old Nov 13, 2010 | 02:44 PM
Faast Ed's Avatar
Faast Ed
Pre 07 Big bore kit gets you 95"
07 up Big bore kit gets you 103"
Then there is the 6 speed, bullet proof tensioners, and frame improvements.
Usually the guys that push the older models are ones that have the older models and can't afford the newer models.
Old Nov 13, 2010 | 02:49 PM
skidder's Avatar
skidder
Well put about the older models.
Old Nov 13, 2010 | 03:13 PM
cornishman's Avatar
cornishman
Originally Posted by rmatt34
I'll agree with you on everything except on point ..(as much as I loved my Evo Dyna) ..
The key switch in the neck is EFFFING RETARDED !!! and it's spring loaded to boot, so if you turn your bike off and leave the key in, your bike will kindly spit it on the ground for you..
This new location is the most awkward thing I have ever seen ...
I could put my key in under my right leg without even looking on the EVO... (and it was right next to the battery)
A Chuck Norris round house kick to the face to who ever came up with the new ignition location..
Other than that, I love my '07 Street Slob !!!
Could,nt agree more regarding the key.
Old Nov 13, 2010 | 03:42 PM
Faast Ed's Avatar
Faast Ed
I never heard about that one before. Ouch!
Old Nov 13, 2010 | 03:56 PM
rmatt34's Avatar
rmatt34
Yeah dude it sucks... try it some time... I really miss my Evo
And I remember vividly when the Evo came out and no one wanted anything to do with it... "not a real harley" etc. etc. ... my how things have changed...
Old Nov 13, 2010 | 05:09 PM
bigdaddy33's Avatar
bigdaddy33
I think it was bobnehoc in an earlier thread who said to just grind the damn nub off and put the damn key in your pocket. Problem solved.
Old Nov 13, 2010 | 05:17 PM
Faast Ed's Avatar
Faast Ed
This is true. However, for those that normally mod their motors, it's a non issue. While some of the heat comes from the lean condition, most of it comes from the epa cams that want to burn the fuel so thoroughly.
Adding fuel to the stock cams helps some, but once you swap cams (even for the mildest cam) you forget that a heat problem ever existed!
For those that like to keep 'em stock, the heat remains an issue. Adding fuel (even xied's) will relieve some of that, but not entirely.
Regardless, the newer bikes are indeed better.
Old Nov 13, 2010 | 05:33 PM
rmatt34's Avatar
rmatt34
If I wanted to put the "damn key" in my pocket , why would I grind the nub off..
I'm talking about when you just want to shut it off for a minute (like stopping on side of road or waiting for you buddy to fuel up ...)
So I should take my gloves off, take the key out and put it in my pocket while I wait for some one to fill their tank. then when they are done put the key back in , put my gloves back on and hope it doesn't spit my key out in the meantime ?
That makes sense..... did you design this thing ?
It's a we todd did design ...period ...
Old Nov 13, 2010 | 05:36 PM
Faast Ed's Avatar
Faast Ed
On my softail, the key almost never see's the ignition.
Hard for me to relate to this key-spitting thing.
Perhaps he meant that grinding the nub would allow you to ride keyless?
