Handle Bar Controls
Old Nov 30, 2010 | 05:41 PM
ktrick01's Avatar
ktrick01
Default Handle Bar Controls
I recently bought a 2007 Super Glide. I had a Softail which was easy to adjust the handlebar controls (clutch, brake). Seems to me that I need a special tool to adjust these controls. They look like Allens, but I've tried American & Metric, they just don't fit. Is there a special tool? Thanks in Advance.
Old Nov 30, 2010 | 05:51 PM
fiend138's Avatar
fiend138
Torxs head
http://en.wikipedia.org/wiki/Torx
Old Nov 30, 2010 | 07:05 PM
R_W_B's Avatar
R_W_B
Post
Pretty sure it's T-25 Torx for the switch clamps and T-27 Torx for the clutch and brake clamps. Make sure and put some blue loctite on them. I torque them to the lower specs (since I had some come loose one time) but be carefull with a torque wrench on these. Clean the threads good with a wire brush before putting the loctite on them. And if it feels like you are torqueing them too much (before the click) ! STOP !. They are small fragile looking bolts. On my Dyna the brake and clutch clamp specs are 60 inch lbs and the switch clamps are 35 inch lbs. But the last time I put them on I stopped short and then set the wrench back to 50 inch lbs on the clutch and it clicked then so I left it alone. Sometimes you have to feel what's going on with these fragile bolts unless you want to have to buy new parts.
The loctite is important on these though.
Whitebrad25
Mar 19, 2014 09:24 PM
Tangle Eye
Jul 7, 2013 12:08 AM
P51Driver
Oct 10, 2012 03:18 AM
Austin Dave
Aug 15, 2011 06:36 PM
R_W_B
Dec 9, 2010 04:12 PM
