Gas tank years difference?
Old Dec 9, 2010 | 06:47 PM
Gwjvw's Avatar
Gwjvw
Default Gas tank years difference?
What is the difference between a 2010/2011 from the 2009? I see all kinds for sale for my bob and they look the same? But no one know why?
Old Dec 9, 2010 | 09:54 PM
U-234's Avatar
U-234
The Dynas have used 3 tanks from 2004 to 2010.
Tank 1 = FXD, FXDX, FXDC, ‘07 FXDSE
Tank 2 = FXDB, FXDL, ‘08 FXDSE, '10 FXDWG
Tank 3 = FXDWG to '08, ‘06 FXDI35, ‘07+ FXDC, ‘08+ FXDF, '09+ FXDFSE
No info gathered on the '11 yet.
Old Dec 9, 2010 | 10:20 PM
A1ACruiser's Avatar
A1ACruiser
Will a 2010 FXDB tank fit my 2010 FXD?
I am wanting to give my Super Glide a Street Bob look with the tank and the mini apes, cables, ect. I want to eliminate the speedo on the bars. Do I have to change the risers also?
I want to buy a C&C seat. I have a fuel pack under the seat.
"C&C seats fit properly on HD stock bikes only! C&C seats Will Not fit any After Market Frames, Tanks, or Fenders, correctly! C&C seats will not fit any aftermarket parts, no power commanders, or other module for pipes or fuel injection that go under the seat".
Old Dec 9, 2010 | 10:22 PM
Gwjvw's Avatar
Gwjvw
HD says tank 2 does not fit the 2010 wg but up till 2009? 2010 and 2011 are the same.
Old Dec 9, 2010 | 11:28 PM
fizzy55's Avatar
fizzy55
i would like to know what is the differance between #2 and#3?
i guess what i'm asking ,will a 08 fat bob tank fit on a 07 street bob,other that the wiring for switch.or is the differance in the dash/speedo?
Old Dec 10, 2010 | 10:14 AM
07bobber's Avatar
07bobber
I call BS....im pretty sure a 06-09 tank will fit a 10' model unless its a fat bob or wide glide....
Old Dec 10, 2010 | 05:53 PM
Gwjvw's Avatar
Gwjvw
i wish
Old Dec 10, 2010 | 06:13 PM
bberck's Avatar
bberck
All the tanks will mount up fine to the bike it's the consoles and speedos that won't mount to every tank.
The list above is correct
Tank 1 has no speedo spot
Tank 2 is the smaller tank and uses the 4 inch speedo
Tank 3 is the larger tank and uses the 5 inch speedo
The WG used tank 3 through 08, when it was brought back in 10 it went with tank 2.
Old Dec 10, 2010 | 06:22 PM
8541hog's Avatar
8541hog
Exactly right. Any EFI Dyna tank will bolt right up, it's the consoles that are different due to the way they mount on the tank.
So if you want to swap, get the complete tank setup.
I run an FXD tank on my FXDWG, bolted right up.
Old Dec 10, 2010 | 07:43 PM
U-234's Avatar
U-234
Thanks bberck. If you don't mind I'll add the additional info to the tank specs that I got from you and others. This may help keep you from having to repeat it ever-so-often.
Were there any changes for the 2011 or can I just change 2010 to 2011 in the info?
All the tanks will mount to the bike.
The consoles and speedos won't mount to every tank.
Tank 1 has no speedo spot.
Tank 2 is the smaller tank and uses the 4 inch speedo.
Tank 3 is the larger tank and uses the 5 inch speedo.
The WG used tank 3 through '08. When it was brought back in '10, it went with tank 2.
