will a Rocker-C or Deuce rear wheel fit a 2007 Streetbob
Old Dec 9, 2010 | 09:33 PM
snooper0069's Avatar
snooper0069
Default will a Rocker-C or Deuce rear wheel fit a 2007 Streetbob
I want to change my rear wheel from stock 4.5 to 5.5 or 6". Will a Rocker -C or deuce rear wheel fit. If so how much of a problem will it be . Will it bolt up or will i have a spacer issue among other things.
Old Dec 9, 2010 | 09:43 PM
Tat2u's Avatar
Tat2u
The Rocker C has a 240mm tire ... so ... no that won't fit !!
Widest tire you can go without major mods is a 200mm tire on the 5.5" or 6" rim
Old Dec 10, 2010 | 12:13 AM
stng_96's Avatar
stng_96
word
Old Dec 10, 2010 | 05:12 AM
nkauf21's Avatar
nkauf21
I can't speak for the sizes of the two wheels mentioned other then a Rocker wheel is wider then 6". I can say that a 5.5" wide rim will fit with no mods with a 180 tire on it. I'm running an 18x5.5 laced to my stock hub with a 180.
Old Dec 10, 2010 | 08:25 AM
JRK5892's Avatar
JRK5892
not even close, i have a set of rockers in the shop right now and put them up to the back end yesterday as a joke... not even close
Old Dec 10, 2010 | 10:56 AM
RonnR's Avatar
RonnR
Yes and No,, The deuce I put on was a 4.5''. So yes the Deuce will fit. No you'll not have to change to a wider rim to do it.. Axle requires a little work, but not much..
Old Dec 10, 2010 | 06:02 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
My rear roadwinder was for a 2005 deuce
kidn1980
Oct 30, 2016 12:22 PM
mrodff
Aug 29, 2014 11:59 AM
bdawg
Apr 8, 2010 07:22 AM
jcmusic
Mar 26, 2009 12:52 PM
Crazy Canuck
Nov 10, 2005 10:13 PM
