Odometer Console button
Old Dec 23, 2010 | 05:39 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Streetbobster
This all you need and you should be able to find it a local electronics store and just splice it in.
http://www.allelectronics.com/make-a...SH-OFF//1.html
$1.85
Don't understand why the link comes up blank? Drag link to search bar and you can open it up.
Good find, click on "buy now" and look at the top right side of the page.
BLACK RUBBER BOOT/CAP FOR PB-21
CAT# WPC-2 $0.30 each 100 or more $0.20 each
Quantity: Buy Now
SPST PUSHBUTTON, PUSH ON/PUSH OFF
CAT# PB-21 $1.85 each 100 or more $1.50 each
Quantity: Buy Now
Old Dec 23, 2010 | 07:04 PM
NoLongerAmember's Avatar
NoLongerAmember
Quantity: Buy Now
Quantity: Buy Now
Actually I posted the wrong switch, it needs to be NOMC Normally Open Momentary Closed
http://search.digikey.com/scripts/Dk...words=562pb-nd
$2.60
Old Dec 24, 2010 | 06:37 AM
WIDERGLIDER's Avatar
WIDERGLIDER
Wow thanks streetbobster! I assume I will have to solder it in?
Old Dec 24, 2010 | 08:25 AM
WIDERGLIDER
$2.60
Funny how the part is $2.60 but the shipping is $8.99!
Old Dec 24, 2010 | 09:21 AM
WIDERGLIDER
For future reference the switch part number is 67488-04
Old Dec 24, 2010 | 10:57 AM
WS6 Formula
Another option is the newer horn switches that come on the Fat Boy as well as other models. Top side of horn switch replaces the odometer / trip / clock switch on the console.
Old Dec 24, 2010 | 11:27 AM
dyna rider's Avatar
dyna rider
Default Switch
WIDERGLIDER- I'm pretty sure it isn't a solder process but crimping a terminal end on the wires and then slipping them into the plug.
Old Dec 24, 2010 | 12:00 PM
WIDERGLIDER
I checked the harness and in order to do that I have to pull apart a few zip ties, pull the wires from the sleeve, etc., not too comfortable with that. What about just spinning the wires together and wrap with electrical tape? Wouldn't that be good enough? That way I don't have to tear apart the harness...
Old Dec 24, 2010 | 12:01 PM
WIDERGLIDER
Wonder how in depth the install would be? Rewiring? etc?
Old Dec 24, 2010 | 12:12 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
I'm not a big fan of "just spinning the wires together and wrap with electrical tape"!
Splicing, soldering and using shrink tubing is the best way to do it; check out this post by Citoriplus: https://www.hdforums.com/forum/2801748-post524.html
Could you post an image of the current situation in order to be able to give you the proper guidelines?
