Before and after photos
Old Oct 2, 2006 | 10:34 PM
spence's Avatar
spence
Default RE: Before and after photos
where did you get the AC skull?
spence
Old Oct 3, 2006 | 12:54 AM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: spence
spence
Skull Air Filter Cover Link
Old Oct 3, 2006 | 02:10 AM
kimo's Avatar
kimo
Love your bike. Kinda makes me green with envy. [8D]
Old Oct 3, 2006 | 06:12 PM
Ash's Avatar
Ash
hEY THANKS!!!
Old Oct 10, 2006 | 12:21 AM
jackyl's Avatar
jackyl
ORIGINAL: WS6 Formula
I edited in some front shots in above.
As far as handling......not what I expected....smoother ride, the side walls must be softer. It feels like a totally different bike, it has better low speed stability(1/2* more rake then the Low Riders triple clamp, total now is 31*), the bike feels lighter, very nimble, its so easy to take a turn or change lanes, very little effort, I guess because of the wider forks, it gives you an advantage like holding a bicycle tire and having someone spin it, and when you try and turn it your fighting that gyro, then doing the same but using a longer axle you get a better mechanical advantage.
did you use your stock fork tubes or went with the whole wideglide front end,or just the triples?
Old Oct 10, 2006 | 12:39 AM
WS6 Formula
jackyl,
Here's what I used: 21" wheel from a wide Glide, upper and lower triple clamps, axle, axle spacers, 3/4" spacers and 3/4" longer Allen head bolts for mounting the fender, and stainless washers for shimming (.040" for the caliper &.090" for the rotor) to center the caliper over the rotor. Use other existing hardware from your bike (axle nut, triple clamp pinch bolts, head bearings and nut, fender nuts, forks).
Old Oct 10, 2006 | 12:42 AM
jackyl's Avatar
jackyl
thanks,ive been thinking of doing this over the winter.i love how it looks on your bike.i would like to do the same to my bob.thanks jackyl
Old Oct 15, 2006 | 03:38 AM
WS6 Formula
A couple more modifications / before and after shots
Old Oct 15, 2006 | 09:30 AM
WdGldDave's Avatar
WdGldDave
Nice. The WG front end really looks great from this angle
[IMG]local://upfiles/5489/A10CBAFC7E3F4A9EBDBB6507C5395400.jpg[/IMG]
Old Oct 15, 2006 | 10:07 AM
jaysonL's Avatar
jaysonL
JMO, but, that is one of the best looking bikes on the board. I love the green/black color, pipes look great on the L.R., what are they btw ?
