Question on throttle cables
Old Jan 10, 2011 | 07:46 PM
ed gien's Avatar
ed gien
Default Question on throttle cables
I'm trying to install new throttle/idle cables on my 14" apes and I'm having problems with throttle response? Not sure if I did not sand the bars enough(got new bars and the grip was tight on them due to over chroming) or I needed to position the grip at a certain point so the cables can be adjusted right?
Anyone come across same problem? The grip goes down but the return is slow and weak.
Old Jan 10, 2011 | 09:44 PM
8541hog's Avatar
8541hog
Does your throttle grip have a sleeve or just the grip. How did you secure it to the bars?
Old Jan 10, 2011 | 09:50 PM
SURFOR Chop's Avatar
SURFOR Chop
You might check the adjustment of the throttle/idle cables ... if there's too much tension on the throttle cable, it'll be slow returning to the idle position ....
R/
'Chop
Old Jan 11, 2011 | 06:58 AM
ed gien's Avatar
ed gien
It was the over thickness of chrome,had to sand down, hated to do it but didnt want to re-do all wiring
Old Jan 11, 2011 | 02:11 PM
nkauf21's Avatar
nkauf21
What brand apes did you go with?
Old Jan 11, 2011 | 05:35 PM
arkieollie's Avatar
arkieollie
Make sure your "cruze control" is backed all the way off. I farted around with my throttle for more than I care to remember because it was slow to come back and after taking a break my son said ".....what's this thingee?" and then it dawned on me. I guess it must have gotten turned while I was taking off the old grips. Yes, I felt like a dumba$$!!!
Old Jan 11, 2011 | 05:51 PM
OldMike's Avatar
OldMike
If the bend in the cables is too sharp because of cables being too short, this can cause a stiff throttle or if the cables are not routed correctly. I assume the throttle is smooth and turns easily without the cables attached.
Good luck,
Mike
Old Jan 12, 2011 | 06:22 PM
NeverEnoughToys's Avatar
NeverEnoughToys
Been there. Done that. Got the t-shirt.
Old Feb 21, 2011 | 09:50 PM
A1ACruiser's Avatar
A1ACruiser
http://www.youtube.com/watch?v=QxglqX40-84
Old Apr 11, 2011 | 08:16 PM
A1ACruiser's Avatar
A1ACruiser
Good luck,
Mike
WTF Something is not right with this picture. What did you do to your motor?
DrRude
Sep 4, 2014 03:47 PM
Russian
May 30, 2014 10:28 PM
rooti
Feb 9, 2014 10:56 AM
bigrob219
Jun 21, 2012 06:06 AM
Superfly3176
Mar 12, 2012 12:35 AM
