throttle Stick
Old Mar 11, 2012 | 11:31 PM
Superfly3176's Avatar
Superfly3176
Default throttle Stick
So I raised the bars up a few inches and just wondering if anyone else had this problem when raising handlebars. I did a full throttle test from left all the way to right all the way. When I pulled open the throttle on the right it stuck. Didn't have this problem in the past before raising it up.
So I adjusted the cables and then tested again and it didn't stick and recoiled back to it's original spot across the full turning spectrum. I'm just wondering if I'm good to go now or if I need to look into it further.
Old Mar 12, 2012 | 12:35 AM
navd's Avatar
navd
my 2 cents:
If you adjusted the throttle/idle cables properly you will be good to go. It can stick if tension is added on the cables.
Iarecobra
Jan 2, 2015 08:06 AM
Russian
May 30, 2014 10:28 PM
OldTyme
Sep 12, 2012 09:29 PM
bigrob219
Jun 21, 2012 06:06 AM
ed gien
Apr 11, 2011 08:16 PM
