FLHT 2001 throttle cables trouble
Old Oct 9, 2012 | 10:39 AM
Russian's Avatar
Russian
Stage II
Default FLHT 2001 throttle cables trouble
Trying to install throttle cables to EFI bike.
Throttle grip is not returning...
couple of questions-
there are three places to put cables on the throttle body, and main throttle cable is inserted at first.
when I'm trying to install idle cable it sits realy bad because of small spring:
when I'm trying to adjust cables grip are not returning...
where I'm wrong?
Attached Thumbnails FLHT 2001 throttle cables trouble-image.jpg   FLHT 2001 throttle cables trouble-image-2.jpg
Old Oct 9, 2012 | 11:38 AM
mikelikesbikes's Avatar
mikelikesbikes
Are you sure it is still in place at the throttle? I helped with this once and found about 6 hands were needed. Hopefully somebody else can give you some better advice.
Old Oct 9, 2012 | 11:47 AM
Russian's Avatar
Russian
Stage II
throttle grip without cables rolls well, cables are new and not broken
throttle body rolls good too
I'm going little bit mad
Old May 30, 2014 | 11:10 AM
Electra45's Avatar
Electra45
1st Gear
What did you figure out.. I'm havering the same problem.
Old May 30, 2014 | 11:26 AM
ZUTEDUFF's Avatar
ZUTEDUFF
if they were not run thru the fairing or down the frame tube close to where the originals came from they can bind.. might check out that out.... also might take the return cable off and see if the grip snaps back then...may have binding there also...
Old May 30, 2014 | 10:28 PM
twincam47's Avatar
twincam47
collapse the return and pull cable adjustment. adjust the pull cable first to get 99% of slack out then adjust return cable. keep twisting the throttle and let it snap back when adjusting return. when snap back lessens then stop adjustment and lock cable adjusters. so pull side first then return adjustment.
the two are fighting each other if not done in this order.
DrRude
Sep 4, 2014 03:47 PM
OldTyme
Sep 12, 2012 09:29 PM
bigrob219
Jun 21, 2012 06:06 AM
Ventana
Sep 17, 2011 05:10 PM
KRUSE
Apr 1, 2008 02:40 PM
