Master cylinder cover help!
Old Jan 13, 2011 | 12:33 PM
JRK5892's Avatar
JRK5892
get a new gasket and just snug it up.. that is all you need to do
Old Jan 13, 2011 | 01:26 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
New gasket is p/n 45483-05
Old Jan 13, 2011 | 02:51 PM
HATZO1's Avatar
HATZO1
Originally Posted by reded
Mine started leaking last year. I tried everything and couldn't get it to stop. Now the fluid has eaten all of the paint off around the outside edge of the cap, looks like $hit. I'm gonna get a new cap and gasket and hope that fixes it.
Same here.
Old Jan 13, 2011 | 09:30 PM
coop creek's Avatar
coop creek
The "new and improved" gasket is thicker/taller for a better seal. I actually replaced the entire master cylinder assembly which includes cap, gasket, resevoir and brake lever for $118. It was not very hard to do. The banjo bolt is a weird part, 12 points or something, so I had to buy a wrench to fit it, otherwise, fairly straight-forward.
Old Jan 13, 2011 | 09:38 PM
Rajin Cajun's Avatar
Rajin Cajun
i would get new one you prob pinched gasket
Old Jan 13, 2011 | 09:59 PM
Knucklehead15's Avatar
Knucklehead15
New lid with gasket cost me just over $20. HD knows about the problem and the new replacement is "better". Some were covered under warranty mine was not. It was a service bulletin.
Old Jan 14, 2011 | 01:07 AM
FXD2003Rider
Originally Posted by coop creek
...The banjo bolt is a weird part, 12 points or something, so I had to buy a wrench to fit it, otherwise, fairly straight-forward...
Front brake master cylinder fitting single disk p/n 41739-84A has a 11mm 12-point socket; more m-sizes to be found over here:
***dyna models metric sizes database***
Multiple options:
11mm 12 point socket:
10 & 11 mm 12 point ring wrench:
11 mm 12 point combination wrench:
10 & 11 mm 12 point tube wrench:
These are the ones I have in my toolbox:
Old Jan 14, 2011 | 03:10 AM
Topspin's Avatar
Topspin
I bought a brand new Master Cylinder on eBay for $20. Couldn't stand the look of the crinkled paint on the old one. Oh... and no more leak! Same cover and gasket too.
Old Jan 14, 2011 | 04:47 AM
Poisond 08 Fatbob's Avatar
Poisond 08 Fatbob
The paint on the lid of my '08' fatbob is bubbled up from the fluid leaking. I've never had it off. Waranty is up so when I replace mine this year it'll come out of my pocket.
Old Jan 14, 2011 | 05:04 AM
nkauf21's Avatar
nkauf21
Does anyone have the p/n for the new and improved cover and gasket set that they sell?
