Ok so i am considering installing my handlebars, risers and grips when i get the correct risers for my handlebars... I was looking around the website specifically in the Do It Yourself Help forum and didnt find to many threads on installing handlebars. Was looking to see if anyone has seen a thread on installing some after market handle bars, preferably for the fxdf.
Thanks Guys..
+1000! This post walked me through the entire procedure. It is probably the definitive post on do-it-yourself handlebar change. Just take your time and go step by step.
While that write is a very thorough and good start, it leaves out one important step.
When accessing the wiring harness, DO NOT just start pulling on the harness from the neck end. Remove the seat and anything under the seat, down at the bottom you will find a large loop of wire, this is the wiring harness running up the backbone. You need to use a push pull method to easily work the wires forward. When re-installing everything replace the loop the same way with a push-pull to get the slack back under the seat. Just pulling from the front MAY damage the wires as the slide through from under the seat.
