I wonder whether you can convert to dual front brakes with the wide glide front end? And whether you can put Buchanan Excel Aluminum spoked wheels on your current hubs? If you could do both, you'd have a much different handling bike. They would be vast improvements over the stock wheels/brakes. Jay
There are several issues about modern bikes, comparing the old and the new. Wheels are a bit like chains v belts, EFI v carbs, and the new stuff does have some merits. Once it was disc v drum brakes! I no longer have any wire-wheeled bikes. I like tubeless tyres and the ease of cleaning cast wheels and don't think I will ever buy a spoked-wheeled bike again. My oldest bike is my 21 year old Glide, but I don't spend much time looking over my shoulder, I'm still heading towards the horizon.
Reason: Spelling!
I rode sportbikes with mags for 20 years, so when I wanted a classic machine to scoot around on I wanted Laced spokes.That was why I bought the Street Bob. I also took it one step further and bought a bigger wider set from Blackbike wheels. There are downsides like many have said already, harder to repair on roadside, and requiring a possible tune up at a later time, along with being harder to clean. But they are classy, and I get compliments all of the time as well.
I want to also add that if you REALLY want to run tubeless with spokes it IS possible to seal the spokes and run tubeless. The downside to this is when and IF they require retruing that the seal is damaged and they must be stripped of rim sealant and resealed which is a bit time consuming, but required. I ran TRUE wire wheels on my Buick Regal Low Rider for many years, and never had to retrue them and only had to reseal one due to me damaging the sealant with the tire machine upon breaking the bead, and not being quick enough releasing the pedal. The bead breaker punctured the sealant.
I may consider sealing my rims upon next tire swap, but doubt it. If a guy used Heavy Duty MOOSE brand Off road tubes I doubt a guy would EVER have to worry about a flat on the road,(excluding major tire /rim damage) Those tubes are like 4mm THICK. Can you tell that I am waving a flag for Laced Rimes
