Ness Fairing Mounting... Help
Old Jan 30, 2011 | 06:54 PM
Dyna_in_the_works's Avatar
Dyna_in_the_works
Originally Posted by Desertram800
What handlebar/riser setup do you have? If you have tall risers or t bars, check out venturaoutfit's mount. Google "custom shortened thunderheader" and click on the result that is on hdforums, and youll see one of the sickest dynas on the site! He's got some great pics of how he mounted his fairing. I use the hd quick disco's, but then again im running the hd 1/4 fairing, not the ness...
Ive got a set of 28" wide 11" tall tbars sittin on 1.5" riser extensions.
Thanks for the input ill check his mounts out.
Old Jan 30, 2011 | 06:58 PM
Aaron 09FXDB's Avatar
Aaron 09FXDB
I am not sure the part numbers, but I went to the local HD dealership and had them look up the part numbers. Here's another thing I found out after I ordered mine and put it together. They also make LOCKABLE ones via a key. So you could get one of them lockable and the other regular, that way it can't be stolen. I should've done that sooner, and may swap one of them out soon.
Old Jan 31, 2011 | 05:15 AM
Dyna_in_the_works
Can you post a pic or two of the mounts you have close up so i can get a look at them before i go order them?
103bob
Jul 20, 2017 08:10 AM
K33b
Feb 5, 2015 02:39 AM
Clown Shoes
Feb 2, 2014 11:41 AM
Dru
Jun 3, 2011 09:15 PM
RandyDowdy
Aug 21, 2010 12:55 AM
