Removing Reflectors
Old Jan 30, 2011 | 06:05 AM
artpe54's Avatar
artpe54
Default Removing Reflectors
I need a good way to remove the rear red reflectors on my FXDC without damaging the paint. Any suggestions?
Old Jan 30, 2011 | 06:11 AM
Robbie13's Avatar
Robbie13
LOSER
I found that a heat gun works pretty good. I just heated them up a bit, got a small angled pick tool up under the edge of the reflector and gently pulled it off. You can usually roll off the remaining adhesive from the paint.
Old Jan 30, 2011 | 06:14 AM
Notgrownup's Avatar
Notgrownup
Hair dryer if you ain't got a heat gun and GOO GONE.... or the label remover stuff from the auto part store...
Old Jan 30, 2011 | 06:18 AM
Iceman24's Avatar
Iceman24
Yep, like others said, got to heat the epoxy a bit, get a corner started & work them off slowly. From there - just remove remaining glue w/goo gone & buff w/some wax.
Old Jan 30, 2011 | 06:19 AM
Robbie13's Avatar
Robbie13
LOSER
+1 on the adhesive remover. That stuff works good.
Old Jan 30, 2011 | 06:53 AM
Beerswimmer's Avatar
Beerswimmer
I used a hair dryer to warm it up, then used my man-hands to teist them off. Acetone(fingernail polish remover) got the sticky stuff cleaned up.
Old Jan 30, 2011 | 07:06 AM
artpe54's Avatar
artpe54
Thanks everyone, appreciate the help!
Old Jan 30, 2011 | 07:16 AM
redmonster13's Avatar
redmonster13
I used fishing line and a hair dryer then some goo gone.
Old Jan 30, 2011 | 08:18 AM
snookums's Avatar
snookums
I used WD-40 and fishing line. both on the forks and the fender struts.
Old Jan 30, 2011 | 09:23 AM
artpe54's Avatar
artpe54
Thanks
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
