Need Help! on idle cable!
Old Sep 3, 2014 | 11:59 AM
CACruiserHD's Avatar
CACruiserHD
When I installed new bars my throttle wasn't returning either. Turns out they powdercoated the whole bar including where the grip goes and it was just enough to make the grip tight. I had to sand the whole area to bare metal & then it worked fine.
Old Aug 17, 2020 | 11:30 AM
pigoff's Avatar
pigoff
4th Gear
Default Long time...
Dude, it’s been quite some time you rote it, bit do you know were did this diagrama came from? Thanks!
Originally Posted by SURFOR Chop
Once installed properly, it shouldn't make any difference if there is 'slack' in the cables ... or even if the throttle and idle cables are exactly the same length ....
Sounds like maybe (i) the spring is not reinstalled correctly to 'spring-load' the throttle butterfly valve (goes up behind "8" in the TB diagram) ... (ii) one of the keepers is not installed correctly to secure the ends of either the throttle or idle cable ends (the little ferrule that the ball seats into item "14" in the grip diagram) ... (iii) the cable expander nuts are not set ... although this would pretty much have to assume either (i) or (ii) were also true ....
The service manual describes the steps, but I find these illustrations can be pretty useful as an aid in helping describe something like this ... hope it helps ....
One other thing is that sometimes the cable sheath gets hung up on the guide sleeves on the IAC bracket that the spring hooks on ... make sure that the cable sheats are seating properly ....
R/
'Chop
Old Aug 17, 2020 | 11:51 AM
nevil's Avatar
nevil
Looks like it's from a parts microfiche. Such as: Ronnies OEM Parts Finder
Old Aug 17, 2020 | 12:48 PM
pigoff's Avatar
pigoff
4th Gear
Default Retaining rings
Thanks.
I’m having an issue with the retaining rings, they are os different sizes / thickness and I Don’t know witch is the throttle and witch is the idle one.
I can’t make the idle one fit the casing...
thanks for any ideas / information.
purpledeuce
Jun 10, 2012 11:52 PM
msamarah86
Jun 22, 2011 07:34 AM
piercings4_u
General Topics/Tech Tips
Apr 8, 2011 03:47 PM
piercings4_u
Apr 7, 2011 05:27 PM
will227457
Aug 21, 2010 01:50 PM
