Slip on Help
Old Feb 1, 2011 | 11:12 PM
deenew33's Avatar
deenew33
Default Slip on Help
I just installed some Vance and Hines straight shots on my 09 Dyna super glide. Got everything back on correctly and getting some leaking at the two connecting sites. i believe I have them tight enough, should I get some new clamps? what should i do.
Old Feb 2, 2011 | 01:25 AM
Foxster's Avatar
Foxster
The clamps are supposed (according to HD) be single use. So ,yes, new clamps sounds like a good plan.
Old Feb 2, 2011 | 01:29 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
What he said.
I have gotten more than one use out of them in the past...but other times not.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Feb 2, 2011 | 01:48 AM
Karsten's Avatar
Karsten
What did you tighten the clamps too? When I changed my 1st set of mufflers I was getting leaks. Inquired what to torque the bolts to and was told 80 ft pounds. Torqued the bolts down and all was well. Used the same clamps for a 3rd set of rush slip ons and torqued to 80 and all was fine.
On the rebuild I switched to BCT Baffles and asked the tech to switch out the original clamps and bolts as they were rusty.
Karsten
Old Feb 2, 2011 | 05:49 AM
deenew33's Avatar
deenew33
Karsten
Not sure Karsten just tightened them down really tight, how can i tell how much tourqe?
Old Feb 2, 2011 | 06:05 AM
Wireguided's Avatar
Wireguided
Are they all the way on?
Old Feb 2, 2011 | 07:39 AM
O.F.'s Avatar
O.F.
My Krome Werks called for 65 lbs. No matter, you're on the verge of buying new anyway so crank on them until they don't leak or break. What's to lose?
Old Feb 2, 2011 | 07:40 AM
pontiac69's Avatar
pontiac69
What he said. I also had some leaking when i had rush slipon put on. I loosened the bolts and took a rubber mallat and hit the end to get them on more. They move about 1/2 inch and no more leaking. So you may want to see if you can get them on somemore.
Old Feb 2, 2011 | 07:47 AM
deenew33's Avatar
deenew33
Well Im going to recheck all the measurements today, I will let you know
thanks
Old Feb 2, 2011 | 07:49 AM
deenew33's Avatar
deenew33
Thanks guys I'm going to break it back down today recheck the measurements make sure they are on all the way before I go buy some new clamps. I will let you know how it goes.
thanks again
