Head Gasket
Old Feb 6, 2011 | 11:58 AM
JimmieJack's Avatar
JimmieJack
Default Head Gasket
I'm changing out the cam and decided to change the head gasket too.
When I pulled the head there was a lot of old gasket material left on the top of the cylinder. What is the best way to clean this up. I don't want to damage the top of the cylinder or bottom of the head. I know if I don't get it right I'll be pulling all apart real soon.
I have a Dremal Tool and some polishing wheels and thought about trying that.
BTW - I'm actually doing this project right now - so any help would be greatly appreciated.
Jimmie
Old Feb 6, 2011 | 12:00 PM
Stiggy's Avatar
Stiggy
Dremel tool would scare the heck out of me...The only way I've ever done it is with a razor blade and maybe some WD 40
Old Feb 6, 2011 | 12:04 PM
Mike T's Avatar
Mike T
Don't use a Dremel to remove it. I use some mild steel wool dipped in gas and a plastic puddy knife to remove it. You don't want any gouging removing gasket material.
Old Feb 6, 2011 | 12:18 PM
Grendel4's Avatar
Grendel4
You can get a 'scuff pad' type of material for your air/power tool that I see mechanics use all the time.
The ones at the top of the photo are what I'm talking about. Do NOT use a razor blade or anything else that might scratch or damage the head and/or the deck of he cylinder. Don't do it.
If you're being cautious (always a good idea) you can pick up some gasket remover and hand-rub the old gasket off with a scuff pad.
No metal or anything sharp or abrasive enough to change/alter/damage the machined surfaces. No way.
Get it all. Smooth as your bride's booty is how you want it.
Old Feb 6, 2011 | 01:05 PM
18wheels's Avatar
18wheels
I disagree, I've been a mechanic for 30 yrs and use gasket scrapers and razor blades all the time, on cast and alunimum parts.. Just be sure NOT to alter the surface your cleaning.. Just take your time and use common sense...
Old Feb 6, 2011 | 01:14 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 use a solvent to loosen the gasket material and razor scraper...go easy. The final clean with xxxx steel wool then spray with brake cleaner to get any residue off.
Old Feb 6, 2011 | 01:15 PM
Mike T's Avatar
Mike T
I've been wrenching for 30 years too but you don't tell someone that you don't know their skill level to put sharp objects on aluminum parts.
Old Feb 6, 2011 | 01:16 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
I'd use some WD40 and an ice scraper:
Old Feb 6, 2011 | 01:42 PM
redrubicon2004's Avatar
redrubicon2004
Those pads you posted up about at high speed can easily remove material from the head surface without knowing it causing a low spot. I use razor blades, you just have to be careful and use common sense.
Old Feb 6, 2011 | 03:55 PM
Stiggy's Avatar
Stiggy
I know what happens when you "***-u-me"...but if you're planning to tear down and reassemble a motor, some assumptions of common sense have to taken. Further, has anyone out there ever seen a blown head gasket due to gasket scraping with a razor blade? Thanks Guys...
