top end tick
Old Feb 13, 2011 | 03:09 PM
SURFOR Chop's Avatar
SURFOR Chop
Maybe the OP is thinking of lifters vice 'risers' ....
Ticking is usually coming from the rocker boxes and is normal valve train noise (within reason) ... the 'Singer sewing machine' sound a couple on here have mentioned ....
If you didn't notice it, can't believe there is much to it ....
Count me in with the 'doubters' ....
R/
'Chop
Old Feb 13, 2011 | 03:37 PM
SuperFastGlide's Avatar
SuperFastGlide
Originally Posted by slider1156
Harley engines, they all tick and ping. Risers ticking WTF is that
im sure he meant lifters
Old Feb 14, 2011 | 12:40 PM
nutter's Avatar
nutter
thanks for the input everyone. to awnser a few of your questions, as far as oil i beleve there was normal oil when i purchesed it in november(i was thinking of running synthetic) the bike had around 14400 when i put it in for storage(i only put 900 since i got it) and yes there was a small sewing machine like tick but i assumed it was normal, im a new rider so i wasent sure
Old Feb 14, 2011 | 12:59 PM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
Pushrod V8s with hydraulic lifters make the exact same ticking noise.
Old Feb 15, 2011 | 02:28 PM
nutter's Avatar
nutter
just heard from the dealer, turns out my cams are blown. good thing is there fixing it at no cost to me because i just baught it from them. gata say there the best dealer ive delt with eveyones wicked helpfull
Old Feb 15, 2011 | 05:15 PM
slider1156's Avatar
slider1156
14,000 miles and cams are gone OUCH. What year is your bike? I would ask them upbout a cam upgrade and make sure it has the newer cam plate that uses the hydraulic tensioner instead of the spring tensioner while there in there
Old Feb 15, 2011 | 07:40 PM
maddghost's Avatar
maddghost
Excellent advice there,even if it costs a few extra bux you will enjoy a cam upgrade over stock!
Old Feb 15, 2011 | 07:49 PM
redrubicon2004's Avatar
redrubicon2004
X2
Are the cam chain tensioners gone? On pre 06 dynas that is actually common usually around 25-30k. I would without a doubt go with the newer cam plate and upgraded tensioners....Swap out the cams while you are in there...You will like it!
Old Feb 15, 2011 | 08:23 PM
nutter's Avatar
nutter
my bikes a 2001 . ill def ask about the updated cam(if i can aford it) whats the diffrence in preformance betwene the two?
Old Feb 15, 2011 | 08:25 PM
SURFOR Chop
'cams are blown' ...? WTF ...?
Cam chain tensioners I might believe ... but, mine were less than a quarter gone at 25,000 miles .... still pretty hard to believe ... have seen them last as long as 75,000 miles ....
