Turn signals - wiring in stems
Old Feb 16, 2011 | 09:04 AM
FXDLgrl's Avatar
FXDLgrl
Default Turn signals - wiring in stems
02 FXDL
The turn signals have been relocated- attached to the lower triple.
The wiring doesn't run thru the stems I have.
Seems to me that Harely offers the newer Dynas the option for internally wired stems, but not the older.
Suggestions?
(btw - certainly don't need the parts to be Harely)
Old Feb 16, 2011 | 10:13 AM
8541hog's Avatar
8541hog
Can you post a pic of the setup? I have not seen any front signals that are wired through the stems, but then I have not seen everything...lol
I looked at doing something similar on mine, but could not come up with a decent way that made a big difference for my front signals. Being attached to the trees, there is no place to run the wires once attached to the trees or forks.
Old Feb 16, 2011 | 10:47 AM
Phrogman's Avatar
Phrogman
You can get these brackets for your forks: http://www.jpcycles.com/product/3300271
Then get some hollow bolts, or have them made locally to the right length: http://www.jpcycles.com/product/381-364
Finally, to plug the hole in your turn signal, go to Ace and get a 3/16" chrome plug and silicone it in place.
Old Feb 16, 2011 | 10:50 AM
8541hog's Avatar
8541hog
The problem with that setup is where do the wires emerge from the bolts, you going to drill a hole in the fork tubes? Or in the bracket, which really does not change anything except about an inch of wire .
Tony Underhill
Electrical/Lighting/Alarm
Apr 20, 2017 07:07 AM
rustybit
Jun 12, 2016 01:11 PM
fatboy1729
Dec 18, 2012 01:17 PM
jm04
Mar 1, 2010 12:07 AM
clayman
Mar 25, 2006 02:02 PM
