Free Mod, air filter cover
Old Oct 9, 2006 | 09:05 PM
WS6 Formula's Avatar
WS6 Formula
Default Free Mod, air filter cover
Old Oct 9, 2006 | 09:06 PM
anubisss's Avatar
anubisss
Default RE: Free Mod, air filter cover
That looks great. What did you use to cut it?
Old Oct 9, 2006 | 09:32 PM
Bradley's Avatar
Bradley
wow, that does look good. how did you get the edges smooth?
Old Oct 9, 2006 | 09:33 PM
crash1292's Avatar
crash1292
ya like the edges wont rust...
Old Oct 10, 2006 | 08:00 PM
Springer 06's Avatar
Springer 06
I have been thinking about doing this... but was afraid to attempt it... was just planning on using my dremel... details would be appreciated.... looks great
Old Oct 10, 2006 | 09:42 PM
WS6 Formula
I covered the aluminum insert with duct tape, then I cut out the center section with a die grinder with a 3" fiber cut off wheel, I put a tight fitting bolt thru the center hole and secured it with a nut, then put it in a drill press on slow speed and used the die grinder to trim the outer edge, then I trimmed the back side edge so you can only see the trimmed edge on the back side of the cover. If your worried about rust, you can paint the back side edge silver. Also the center hole is not exactly centered so you might want to use a loose fitting bolt and center it before you start.
Old Oct 10, 2006 | 10:41 PM
Naz_Man's Avatar
Naz_Man
ORIGINAL: crash1292
The best trick for this is to put some clear finger nail polish on the raw edges, wont rust, drys clear and shinny!
Old Oct 10, 2006 | 10:49 PM
Matrix's Avatar
Matrix
Wow that came out very nice. I'm not quite sure if my bolts that are behind the cover are chromed though. It looks great!
Old Oct 11, 2006 | 12:54 AM
CraigC's Avatar
CraigC
Damn, that looks really good!
Old Feb 8, 2007 | 01:58 PM
sims5's Avatar
sims5
If you drilled a hole first, could you use a band saw to cut the cover?
