Remove the gas tank decals.
Old Oct 10, 2006 | 03:39 AM
wwgilstrap's Avatar
wwgilstrap
Default Remove the gas tank decals.
I want to remove the brushed aluminum harley davidson decals from the gas tank. Their held on with adhesive right?? Any words of wisdom would help.
Old Oct 10, 2006 | 05:19 AM
veniculum's Avatar
veniculum
Default RE: Remove the gas tank decals.
dental floss/nylon fishing line/nylon guitar string....and....a hair dryer. Heat up the emblem for a little bit and just pull the string through. Sould take it right off.
When finished, use some goo gone...or similar...to remove any remaining adhesive.
Todd
Old Oct 10, 2006 | 01:54 PM
wwgilstrap's Avatar
wwgilstrap
Todd, Thank you... I'll give it a try.
Old Oct 10, 2006 | 04:22 PM
lolife's Avatar
lolife
on mine I just peeled the emblem and rubbed the sticky foam with my thumb. looks great. I had a hard time with the reflectors. use heat.
Old Oct 10, 2006 | 06:44 PM
Alaska Bobber's Avatar
Alaska Bobber
I use some 40 pound line off of my salmon pole....use kind of a sawing motion behind the emblem. Then I just peal off the rest with my thumb. I finish it off with a little Goo Gone.
Rear Reflectors are held on with same stuff that holds the International Space Station together.....
Old Oct 10, 2006 | 07:30 PM
CraigC's Avatar
CraigC
Just peel `em off! Use 3M Adhesive Remover if any adhesive remains on the tank.
flangar
Nov 30, 2017 01:41 PM
enginesludge
Dec 9, 2014 11:31 AM
Blackysporty
May 8, 2012 09:42 AM
zonutt
Jan 13, 2010 04:21 PM
yank
Jul 21, 2009 02:21 AM
