Turn Signal security module
Old Feb 26, 2011 | 06:35 PM
VA Biker's Avatar
VA Biker
Default Turn Signal security module
Does anyone know where it is on a 09 Fat Bob?
Old Feb 26, 2011 | 07:41 PM
R_W_B's Avatar
R_W_B
Smile
Probably in the same place it is on my 07 Street Bob. In the fuse box (left side of bike under seat). The TSSM will be the black square box on the left side (facing the bike) of the fuse box.
Do you have a problem with signals or security?
Old Feb 26, 2011 | 08:03 PM
O-Town D's Avatar
O-Town D
"Turn Signal security module - Does anyone know where it is on a 09 Fat Bob?"
See part #15....
Old Feb 27, 2011 | 10:08 AM
VA Biker's Avatar
VA Biker
This will explain. I think I fried it. Idont know.
https://www.hdforums.com/forum/dyna-...ar-lights.html
Old Feb 27, 2011 | 10:32 AM
R_W_B's Avatar
R_W_B
Post
Now for some reason the left sig will not come on. I used a test light and checked the purple wire all the way to the other side of the run,turn ,stop module. I got no power now. The right signal light comes on but just in run mode,it will not blink for the signal or get brighter when I hit the brakes like the left side did earlier.
Hmmm I've have seen this before and a guy nailed it by replacing the Run-Turn module. Try removing the Run-Turn plug in and see if it blinks then.
Now Im finding the bike wont start. When I it the run switch I hear the fuel pump run but the yellow light dosent come on and it wont turn over.
The traced the wire (purple signal wire) back to the turn signal security module on the wiring diagram?
Hmmm this sounds a bit more interesting. Did you check all your fuses? And just for the heck of it check your Fob battery, I had one from H.D. go bad after 4 weeks.
And I guess you know now anytime you are working with electrical, disconnect the neg battery cable first. Put masking tape over the Batt terminal for safety.
Old Feb 27, 2011 | 05:37 PM
VA Biker's Avatar
VA Biker
I did remove the run turn stop module and it didnt change anything. I checked the fuses. The bike wont start. I hit the run button and the fuel pump runs but the yellow engin light dosent come on. It wont turn over,.
Im not sure what to do at this point.
Old Feb 27, 2011 | 06:36 PM
R_W_B's Avatar
R_W_B
Smile
I did remove the run turn stop module and it didnt change anything. I checked the fuses. The bike wont start. I hit the run button and the fuel pump runs but the yellow engin light dosent come on. It wont turn over,. Im not sure what to do at this point.
Ok I'm checking with some other guys on this. In the meantime please refresh me on the background. I realize the bike doesn't start but just to cover bases.
1. One rear sig works other doesn't correct ?
2. Do the front sigs work ?
3. Did you switch bulbs in the sigs? (if it's the rear it's prolly single element but just to cover bases)
Don't rush off just yet for a $1XX.xx TSSM, let me see what I can find out first, then maybe.
Old Feb 27, 2011 | 06:49 PM
VA Biker's Avatar
VA Biker
[QUOTE=R_W_B;7978585]Ok I'm checking with some other guys on this. In the meantime please refresh me on the background. I realize the bike doesn't start but just to cover bases.
1. One rear sig works other doesn't correct ? right side comes on but dosent blink or get brighter when i hit the brake.left side dosent come on
2. Do the front sigs work ? they come on but dont blink
3. Did you switch bulbs in the sigs? (if it's the rear it's prolly single element but just to cover bases) the bulbs are the original single element
Don't rush off just yet for a $1XX.xx TSSM, let me see what I can find out first, then maybe.[/QUOTE
Thanks for the help
Old Feb 27, 2011 | 07:02 PM
R_W_B's Avatar
R_W_B
Smile
(if it's the rear it's prolly single element but just to cover bases) the bulbs are the original single element ... ....
So no sigs blink at all, front, rear nothing but running lights ?
Old Feb 27, 2011 | 07:20 PM
VA Biker's Avatar
VA Biker
Yes, just running lights except left rear dosent come on at all.
