Another Street Bob Brake Light question.
Old Mar 10, 2011 | 10:36 AM
Napper's Avatar
Napper
Default Another Street Bob Brake Light question.
Hopefully someone can help. Took off the stock Street Bob tail/brakelight and put on a two wire brakelight. Black is ground and Red Yellow is brake light. Correct? Anyways with the key on have running light but no brake light. What should I look for? I put on Joker Machine turn signals front/rear with no issues with soldering. Thanks for the help in advance.
Old Mar 10, 2011 | 10:40 AM
trip20's Avatar
trip20
don't know what year your bob is but here's a pic from mud that might help you out:
Old Mar 10, 2011 | 11:45 AM
bobnehoc's Avatar
bobnehoc
It sounds like you are missing a wire....One wire for ground, unless it internally grounds, one wire for running lights, one wire for brake lights......Did it come with instructions or a wiring diagram? Who makes the taillight and do they have tech support?
Old Mar 10, 2011 | 01:01 PM
Napper's Avatar
Napper
Its a 2009. Bought the tail/brakelight at a swap meet.
Old Mar 10, 2011 | 01:37 PM
SURFOR Chop's Avatar
SURFOR Chop
In the wiring diagram Bry posted up, the Orange/White wire is not used on domestic U.S. models ...
The blue lead is tail light/running light, and the red/yellow striped lead is for the brake light ... you need to have the housing of the thing grounded ... to the black lead ....
I just got done (almost) wiring a tombstone tail lamp for my bike ... there were only two leads coming off the lamp, but the outer housing of the light receptical is the ground ... the lamp came with a lead that has to be grounded to the tail lamp housing and run to the wiring circuit ....
I bought a 6-position AMP pin terminal (vice receptical terminal) and crimped on the pin fittings ... I am re-wiring everything to be quick disconnect using the same connectors as stock (the AMP terminal connectors) ....
[The little 'arrows' and 'Y' designate pin connector and socket connector, respectively]
It took me a little while to do my homework ... study the wiring diagrams and the terminology ... also, got to where I now understand the numbering system of the housings so I can trace a wire back ....
Old Mar 10, 2011 | 08:53 PM
jmeiers's Avatar
jmeiers
I just wired up a two-wire, Model-A tail light on my 2010 Street Bob. I used the original brake wires.
Red w/ yellow tracer = Brake Light
Orange w/ white tracer = Running Light
Black = Ground
The ground wire I just wrapped around one of the mounting bolts as I tightened it down. All works great!!!
Old Mar 11, 2011 | 10:11 PM
Napper's Avatar
Napper
Thanks Jmeiers and Surfor Chop. I had a very blonde moment!! I think what threw me off was that the new tail/light have a black and red wire coming out of it and thought the black was ground. Everything thing is good to go now. Thanks again.
Hooligan327
Apr 11, 2021 04:07 PM
Bullridr
Electrical/Lighting/Alarm
Feb 23, 2016 09:40 AM
Roadst1978
Jun 4, 2015 10:15 PM
dudshep31
Mar 30, 2013 10:27 PM
bobber9
Feb 28, 2010 02:58 PM
