AFTER YOU BUY A 2005 SUPERGLIDE
we will see in the coming times, so far since May 7 4000 kms no problems
Lugging is lugging any way you look at it and is not good for your engine regardless. Just imagine the force exerted on the crank when the gas mixture ignites and forces the connecting rod down. Now if the crank is spinning up a bit , this force is translated into a reciprocal motion as opposed to a slow moving crank (ie lugging) where the force exerted by the connecting rod is forced more in a downward motion acting against the crankpin and exerting much more force downward than when it is spinning up a bit. Make sense??
Picture when you lug an engine , the vibration you feel (that hard banging)when you do it, that is the downward force I speak of here that has the distructive nature for your engine.
[IMG]local://upfiles/2318/92E8ECD188774D5A81964374B62130FC.gif[/IMG]
THere have been numerous reported problems with syn in the tranny. Aside from that tranny fluid or most of it is a semi synthetic blend anyway but you need to and must run the right grade of oil in there if you plan on owning this bike for a while. Secondly, why would anyone in their right mind put high dollar synthetic oil in the primary when you could essnetially pee in there and do about as much good as putting syn in there. The oil is only to lube and cool the chain and gears. The clutches are a wet or dry clutch so no problem with them. You can run just some straight 30 weight oil in the primary and be ahead of the game and have everything you need in there and save a lot of beer money.
I hate oil threads but I guess they are a necessary evil for the ill informed.
Sounds Like we have a Viking Choppers guy here on the board. Also sounds like I am new and about to get the boot already for chimming in on this one. LOL
Sorry no flaming I am just amused at the post by the Mechanic dude. Guy you have some good issues and points but sounds like you need to get your stories straight. These people are sharp and don't seem to forget much so beware the posts and remember what you say or it will bite you.
I didn't know how to add the fancy quotes but this is mine and I live by it. " Life is to short to dance with Ugly People". SpiderJim.
P.S. my 04 Rk with 7200 miles that Rk101 helped put about 1500 of them on for me this spring just got it's first does of Amsoil. Also if you don't think Motorcycle oil isn't important then read some oil company reports on air cooled engines and the life blood that keeps them smiling.
