Problem with 06 DYNA
Old Oct 14, 2006 | 03:57 PM
WildBill76's Avatar
WildBill76
Default RE: Problem with 06 DYNA
I was under the impression you should never use syn 3 in the transmision. ( Too Thin) They had withdrawn the three hole statement about their oil when, six speed owners mentioned the gear whine.
Old Oct 15, 2006 | 03:15 AM
bobcowan's Avatar
bobcowan
ORIGINAL: KBFXDLI
check the belt for sure, then get the syn3 outa the trans and use mobil175w90 synthetic gear oil (autozone) or redline shockproof heavy gear oil from www.myoilshop.com
That may not be the best advice. The new 6 speed is a lot differant than the "old" 5 speed. It's like comparing a toploader to a T5.
Old Oct 15, 2006 | 11:27 AM
Motosurf's Avatar
Motosurf
My bike made a sqeaking noise and I found some loose heat shield clamps. Once they were tightened the noise went away!
06 FXDBI
Old Oct 15, 2006 | 03:49 PM
romac's Avatar
romac
My 06 Street Bob made the same sound when I was traveling on the highway especially when it was quite windy (Don't know why) I checked the alignment on my rear wheel and found it was out quite a bit. After I realigned the wheel it seems to have gone away. It never did it prior to having my 8000 km service done by the dealer.
Those services will now only be done by me.
Old Oct 15, 2006 | 10:18 PM
StaticSag's Avatar
StaticSag
I know of a few people here with 06's that have had this same problem, my FXDWG included. They all ended up being loose brads in the headlight. I took mine to the dealer and they replaced the headlight and no more problem. It would squeel like you wouldn't believe but it only did it above 50mph or so. Yours stops when the engine is killed so it may be something else but there have been several with bad headlight around here.
Just a thought....
Old Oct 16, 2006 | 12:49 AM
wlbowers's Avatar
wlbowers
ORIGINAL: EagleArmsHBAR
My 06 Dyna SB is making a weird high piched squeeking sound while driving. If I turn the bike off and work the fork, it makes no sound. It seems to be coming from the forks, but I am unsure. Could this be the 15K problem we were warned about that needs fixing? I have just under 1200 miles on it and just noticed the problem.
That's the brake dragging the pads. Clean the dust off them with some brake cleaner. If it still does it like mine did they had to clean and lube the pins.
jayride
May 10, 2009 10:29 PM
darkdyna06
Exhaust System Topics
Mar 5, 2007 04:25 PM
toby34
Aug 2, 2006 01:47 PM
mtb017
Apr 19, 2006 04:52 PM
HDF Tech
Jan 16, 2006 12:43 AM
