How much weight can a Dyna carry?
Old Mar 16, 2011 | 01:04 AM
Dynafrom818's Avatar
Dynafrom818
Default How much weight can a Dyna carry?
How much stuff can I take with me on a long trip (est 1000 miles)? I want to make sure my bike (05 Super Glide) will not act up or give me any problems. And I certainly don't want to over work her.
It will be myself (190lbs) and a passenger (120lbs) with bags full of junk for one over nighter.
Should I adjust my tires, shocks, etc...? Don't run her over 80mph for too long? As you can tell, this is new to me.
Thanks.
Old Mar 16, 2011 | 01:33 AM
Eddie A.'s Avatar
Eddie A.
subscribed
Old Mar 16, 2011 | 02:09 AM
HemiOrange's Avatar
HemiOrange
Look on your bike's sticker on the front right frame downtube. You will see the gross weight allowances for the front and rear axles (GAWR) along with tire pressures. Add up the two. Now subtract from that number the weight of the bike, bags and accessories, in other words, your bike as it sits, unladened.
So, if your two axle numbers add up to say 1080 pounds and your bike and bags weigh say 650, you can safely carry 430 pounds of rider and gear.
This info is also available in the owner's manual.
Using my example, you will be able to carry 120 additional pounds when riding two-up, since you and your passenger's combined weight is 310 pounds. I'd adjust my shocks to the higher setting.
Edit: Oh, yeah, your saddle bags, etc, also have their own weight limits! There should be a tag inside telling you how much weight they can safely hold, it is much less than you'd think. Just pack the heavy items down low and keep the high bags as light as possible. You want to keep the center of gravity as low as possible.
Old Mar 16, 2011 | 09:33 AM
DSnoopy's Avatar
DSnoopy
Yep, what Hemi said. And it sounds like you will be fine. I have seen people two up that must have weighed 500lbs combined, plus baggage.
Old Mar 16, 2011 | 11:28 AM
huskers11's Avatar
huskers11
You'll be fine. You'll probably be one of the lightest two up bikes on the rode.
Old Mar 16, 2011 | 02:01 PM
Dynafrom818
Thanks guys.!!
Old Mar 16, 2011 | 04:06 PM
bikerlaw's Avatar
bikerlaw
The motor on your Dyna is the exact same motor thats on the Utlra's and they weigh hundreds of pounds more than ANY Dyna made. You can't load enough stuff on that bike to over tax the drivetrain. I have been told 425 should be your max based on the suspension, but just me and my wife weigh more than 425lbs BEFORE we even get another 50 lbs of luggage on it.... and that doesn't even begin to take into consideration all the accessories. Sounds like your well within the bikes rated limits and substantially less that half the fat riders who own them. I think your safe. Tires should be at the recommended pressure and you might want to click up your shocks a notch.
XcellMusic
Jun 26, 2017 10:34 PM
ShiftyCapone
Feb 10, 2014 10:18 AM
iwantalowrider
Feb 9, 2014 07:30 AM
KevenW
Sep 30, 2011 01:50 AM
tomtompiperson
Sep 16, 2009 09:19 PM
