Chirping
Old Mar 16, 2011 | 01:22 PM
Mooseontheloose's Avatar
Mooseontheloose
6th Gear
Default Chirping
My 02 Wide Glide makes a chirping sound when i cross bridges with cement barriers can be very annoying.Any ideas what might cause this.I was thinking baffles or rubber between carb and intake???
Old Mar 16, 2011 | 01:29 PM
JSprGldeMathis's Avatar
JSprGldeMathis
I am subscribing to this thread, my bike has a strange noise like that too, going to be on the lookout for a quick fix or at least something about it...
Old Mar 16, 2011 | 01:44 PM
kk6pg's Avatar
kk6pg
Check the rubber snubber on the frame for the jiffy stand
Old Mar 16, 2011 | 01:51 PM
rh8234's Avatar
rh8234
This subject comes up occasionally. Usually - but not always - a chirping sound is caused by a dirty drive belt. I clean my drive belt with warm soapy water and the wife's tooth brush. Chirping stops, but the wife's teeth kinda get a little funky looking. Not a bad trade off in my opinion.
Old Mar 16, 2011 | 02:00 PM
JRK5892's Avatar
JRK5892
also grab ahold of your intake and wiggle it... if it moves at all tighten it up... i hunted a noise for the longest time and that ws it... do you have an alarm on that bike? could be a lose wire as well casueing the alarm horn to make anoise
Old Mar 16, 2011 | 02:18 PM
SouthpawHD's Avatar
SouthpawHD
Originally Posted by rh8234
.....I clean my drive belt with warm soapy water and the wife's tooth brush. Chirping stops, but the wife's teeth kinda get a little funky looking. Not a bad trade off in my opinion.
That's funny spit!!!
Old Mar 16, 2011 | 08:19 PM
Wide Glide Ride's Avatar
Wide Glide Ride
I had a chirping sound when I got out of the throttle. Tightened the drive belt and it went away.
Old Mar 16, 2011 | 09:06 PM
Mooseontheloose
6th Gear
Too funny!! my drive belt was cleaned when the new rear tire,new brakes and new axle was installed last week.
Old Mar 16, 2011 | 09:14 PM
Mooseontheloose
6th Gear
Ty.. I'll check it again even though I just had a new tire, brakes and a new rear axle installed last week and the belt was cleaned as well.This has been going on since I got the bike in 09.I only hear it while riding at a steady throttle across bridges.
Old Mar 16, 2011 | 09:16 PM
Mooseontheloose
6th Gear
Ty will check that..
