Leak from Chaincase Drain Plug
Old Mar 19, 2011 | 06:20 PM
SouthpawHD's Avatar
SouthpawHD
Easy fix if the primary cover gasket needs to be replaced, so don't sweat it.
Old Mar 19, 2011 | 06:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Clean the area with brake cleaner, great degreaser. Ride till everything good and hot then look for leaks, you might want use an inspection mirror to look up between the primary and transmission . You mention the dealer serviced it, I'd check the trans fluid to make sure its at the correct level when at operating temp.
Old Mar 19, 2011 | 07:51 PM
Stomper-63's Avatar
Stomper-63
On a further note, since it was recently serviced, the tech may have slopped fluid when refilling it, and you may have a pool of the stuff in some nook/cranny that continues to bleed out....
gene431
Mar 24, 2013 09:03 PM
lumberjacker
Jul 30, 2012 05:51 AM
VTwinJaxFL
Jun 21, 2011 02:34 PM
JosephH1
EVO
14
Apr 28, 2011 09:12 AM
electaRICK
May 1, 2008 11:40 AM
