Rigid sideplate info wanted
Old Oct 15, 2006 | 09:28 AM
mikeurig's Avatar
mikeurig
Default Rigid sideplate info wanted
I've seen ridig sideplates mounted on some '06 dyna's and was wondering, Harley says you need the directional relocation kit but you guys still have the lights in the same spot, is that correct?
I should state that I have the wide tire kit installed so maybe that makes a difference.
Old Oct 15, 2006 | 09:43 AM
jmbear328's Avatar
jmbear328
Default RE: Rigid sideplate info wanted
Well if your gonna add saddlebags you will need to move the signals, but on my 06 Superglide all I did was just mount the plates and only took about 20minutes or so. It just mounts behind the strut.
John
Old Oct 15, 2006 | 09:50 AM
mikeurig's Avatar
mikeurig
I don't plan on adding saddlebags, I have a T-bag I use, I think I can get more into the T-bag than those saddlebags.
Thanks for the response, nice ride.
Old Oct 15, 2006 | 09:53 AM
jmbear328's Avatar
jmbear328
Yeah,... I decided against saddlebags as well. I bought this bag off ebay fairly cheap which will work for local and short trips and I'll also get a larger T-bag for long multi-day trips.
John
Old Oct 15, 2006 | 10:00 AM
mikeurig's Avatar
mikeurig
You need a "bigger" bag for multi day trips, lol
Man that's a pretty big bag. I had a T-bag that was expandable and had plenty of room when I went to Wisconsin from NJ in '98 for the week.
Old Oct 15, 2006 | 10:04 AM
jmbear328's Avatar
jmbear328
Well,... This one holds alot but I like the Harley Touring bag that has the seperate levels and also opens from the side, which would just make getting stuff in and out alot easier.
John
Old Oct 15, 2006 | 10:06 AM
Psycho's Avatar
Psycho
I've got a set if you need them Mike. I'll make it worth your time.
As far as relocating the turn signals, I don't know. With the stock tire, my turn signals stayed where they were. I never did have the rigid sideplates and the turn signals in the stock location with the wide tire. The wide tire came later.
You need to relocate your turn signals anyway. The rear relocation kit with the lay down license plate changes the whole look from the rear. Makes the wide tire look even wider, cause it narrows the rear profile of the bike accentuating that tire even more. Looks badass.
Old Oct 15, 2006 | 10:12 AM
mikeurig's Avatar
mikeurig
You have a set of sideplate?
I'm bidding on a used set on Gee-bay right now, I'll see what happens on the bidding.
Sent you a PM.
Old Oct 15, 2006 | 10:39 AM
Psycho's Avatar
Psycho
Well if you don't get those, just let me know and we can work something out on these. I don't need them, would just as well see somebody that needs them get them cheap as to see them sit out there in the shed gathering dust.
Old Oct 15, 2006 | 10:43 AM
mikeurig's Avatar
mikeurig
Will do.
SunPilot
Softail Parts
15
Nov 5, 2014 03:30 PM
bayboy75
Touring Parts
Jun 5, 2014 09:17 PM
ACkeepnitCool
Mar 25, 2014 01:16 AM
Hairy Gary
Aug 24, 2012 09:13 AM
serjayson
Feb 18, 2012 10:09 PM
