I have walked off more times than I would like to admit with the key still in the ignition reminding me to turn it off, hate to think what that would be if it were in my pocket and not thinking about it. Hands down the best mod I made was to move the ignition to the dash, no key needed period and the fob stays in the pocket! What sucks is I find myself still bending over to switch it off every once in a while.
I use a soft key fob....it isn't compulsory for Harley riders to have their keys on a chain you know ;-)
I also used a soft rubber keychain with only my bike key on it....still dulled the frame and actually wore it down to metal in one spot.
Originally Posted by goblin127
So what nub do you file off?
It's the single nub sticking up off the outside circumference of the key....when inserting the key into the ignition it will be at 12 o'clock. Grind/file this nub down until it is gone and you're left with a clean round circle.
I like the idea but I am afraid like many others that I would walk off with the bike still on. I catch myself walking off with the key still in the bike all the time.
As far as key chains scratching my frame I use a small rock climbing style clip for my keys. I just detach the key (bike key has its own key ring) from it the clip when I am ready to ride and use it that way. Nothing dangling from the key to scratch the frame
Just did this...can't believe I didn't think of this before. I've made a habit of using my key to turn the bike off, not the run switch so I'm not worried about leaving it on. Plus with the Dakota Digital guage lit up I doubt I'd ever hit the run switch and walk off without noticing the ignition still being on.
First I cut the red wire running to the ignition and routed it to a toggle switch above my horn. With my filed key, I turned the the key to "Run", and removed the key. Now I keep the key and fob zipped up in my jacket pocket at all times.
To start, and turn the bike off, I just use the toggle switch. The key and fob never leave my pocket. I'd only need the key to lock the forks or use the "ACC", but I very seldom have the need to do that, but I can if I choose. The bike won't start for anyone without the fob, so I'm good.
I just jump on the bike, flip the toggle and hit the start button. Having the toggle above the horn also reminds me to push the compression releases on top of the heads right next to it.
