Riser play after installing 18"apes
Old Mar 24, 2011 | 02:08 PM
scotchy's Avatar
scotchy
Stage II
Default Riser play after installing 18"apes
I just installed a set of 1.25 carlini Fly in apes 18" on my 2007 street bob,Love the look .But there is about a 1" play in the stock risers. the bars step down to 1" .I thought about using a set of polyurethane bushings instead of the rubber mounted ones. any help on this wold be appreciated thanks
Old Mar 24, 2011 | 02:10 PM
HATZO1's Avatar
HATZO1
Put the poly bushings , they will fix the problem for you. I had to with my 16" Apes.
Old Mar 24, 2011 | 02:12 PM
DSnoopy's Avatar
DSnoopy
Yep, bushings needed.
Old Mar 24, 2011 | 02:13 PM
scotchy's Avatar
scotchy
Stage II
Will do , Thanks for the quick response
Old Mar 24, 2011 | 03:34 PM
Spanners39's Avatar
Spanners39
In extreme cases (24" apes+) you can use alloy bushings.
Old Mar 24, 2011 | 07:29 PM
reded's Avatar
reded
Get the poly, the rubber bushings allow the riser bolt to flex resulting in broken riser bolts. Ask me how I know....
Old Mar 24, 2011 | 08:46 PM
PigInaBlanket's Avatar
PigInaBlanket
The stock rubber bushings blew more *** than Oprah after a huge Taco Bell feast. They had a lot of play with the stock apes so when I switched to 14" apes we put poly bushings in and it got rid of the sloppy mess... unlike Oprah.
HevyMetaL
Jul 23, 2014 12:52 AM
Z06John
Apr 4, 2012 10:29 AM
harleyheaven
Apr 5, 2011 07:37 AM
Kevin's_09FXDF
Sep 4, 2010 08:26 AM
05 HD Deluxe
Oct 29, 2008 11:05 AM
